20 Most Recent Technics SL-PD8 5-Disc CD Changer Questions & Answers
power supply failure
The small amplifiers that send the audio to the output connectors are getting corrupted power.
Cheaper to buy a good used player
Technics SL-PD8... | Answered on Dec 16, 2014
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Technics SL-PD8... | Answered on Aug 09, 2014
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa
Technics SL-PD8... | Answered on Sep 17, 2010
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Technics SL-PD8... | Answered on Feb 04, 2010
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
Technics SL-PD8... | Answered on May 03, 2009
This is straightforward. You have to ensure that the disk is stopped by pressing the square symbolled button then press disk skip once or twice and open the tray. Presto (if it is working correctly)
Technics SL-PD8... | Answered on Jan 08, 2009
The answer is yes you do. The replacement laser pickup assembly has 2 motors already fixed to it so the pegs in the suspension have to be removed (2 off) and it is best to prise open the split in the receptacle to facilitate this without damage.Then 3 screws on the pcb need unscrewing and after the solder has been removed on the motors the boards will come apart.
Go to http;//audio.manualsonline.com
Technics SL-PD8... | Answered on Aug 25, 2008
Can you hear a motor running?
If yes then the belt to the turntable has come off or broken.
Regards
Geoff
Technics Audio... | Answered on Jan 10, 2020
Technics SL-PD8 5-Disc CD Changer Logo
Popular Tags
13 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
sl pd8 cd tray opening closing nonstop
  • Audio Players & Recorders
