20 Most Recent
Canon MP Navigator EX for Windows Questions & Answers
How do I scan multiple documents and email them as
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
1/30/2018 6:14:28 PM •
Canon MP...
Answered
on Jan 30, 2018
Tengo una Copiadora Canon IR 1023, a cada rato se atasca el papel, se queda al pasar por el rodillo del termico no sale, se arruga y atasca.
Si tu copiadora Canon IR 1023 se atasca constantemente con papel y se arruga al pasar por el rodillo t?rmico, aqu? hay algunas soluciones y pasos que puedes intentar:
1. Verifica el tipo y la calidad del papel: Aseg?rate de utilizar papel de calidad y del tipo adecuado para tu copiadora Canon IR 1023. Utilizar papel de baja calidad, h?medo, arrugado o demasiado grueso puede causar atascos.
2. Limpia el rodillo t?rmico: Si el rodillo t?rmico est? sucio o presenta residuos de tinta o polvo, puede provocar atascos de papel. Apaga la copiadora, desench?fala y deja que el rodillo t?rmico se enfr?e por completo. Luego, utiliza un pa?o suave y limpio ligeramente humedecido con agua para limpiar cuidadosamente el rodillo t?rmico. Evita usar productos qu?micos agresivos o solventes, ya que pueden da?ar el rodillo.
3. Revisa las gu?as de papel: Aseg?rate de que las gu?as de papel est?n correctamente ajustadas seg?n el tama?o y la orientaci?n del papel. Las gu?as mal ajustadas pueden causar atascos y arrugas en el papel. Ajusta las gu?as cuidadosamente para que est?n en contacto suave pero firme con el papel.
4. Verifica y limpia los sensores de papel: Los sensores de papel son peque?os dispositivos que detectan la presencia y el movimiento del papel dentro de la copiadora. Si estos sensores est?n sucios o defectuosos, pueden causar atascos y otros problemas. Consulta el manual del usuario de tu copiadora para localizar los sensores de papel y c?mo limpiarlos adecuadamente.
5. Realiza un mantenimiento regular: Programa un mantenimiento regular con un t?cnico autorizado de Canon para verificar y limpiar los componentes internos de la copiadora. Un mantenimiento adecuado puede ayudar a prevenir atascos y otros problemas.
Si los problemas de atascos de papel persisten a pesar de seguir estos pasos, ser?a recomendable contactar a un t?cnico especializado de Canon o al servicio de atenci?n al cliente de Canon para obtener asistencia adicional. Ellos podr?n proporcionarte soluciones espec?ficas para tu modelo de copiadora Canon IR 1023 y brindarte un soporte m?s detallado.
What should i do to fix this error? Canon i-sensys mf 9220 showing system error E000003 on screen
What is the Canon i-sensys mf 9220 system error E000003?
The Canon i-sensys mf 9220 system error E000003 is an error that can occur when you're trying to print documents. Basically, it means that the printer can't communicate with the computer. This can be caused by a number of things, but the most common cause is a problem with the USB cable.
How to fix the Canon i-sensys mf 9220 system error E000003?
If you're getting this error, the first thing you should do is check the USB cable. Make sure that it's properly connected to both the printer and the computer. If the cable is loose or damaged, try replacing it with a new one.
I hope this helps!
Can I use my chromebook to print from a Canon MG2522
Chromebooks do not use drivers to install printers. They use Google Cloud print. There are two methods of printing with Google Cloud print, using a Google Cloud Print ready printer or setting up the service on your computer.
