20 Most Recent Microsoft Excel 2003 (065-03992) for PC Questions & Answers
Microsoft Excel is Part of the MS office, and unfortunately it is not free, however Open Office is free and you can do pretty much everything you can do with MS office, for excel they have something called Calc which is a spreadsheet program, it is free and it is good. But if you want MS excel you will have to buy it, downloading a cracked copy is not a good alternative they cause more problems than they solve.good luck
Microsoft Excel... | Answered on Feb 21, 2018
Just search " buy Microsoft excel ".
Microsoft Excel... | Answered on Oct 18, 2015
this is what you do, highlight the cell box that are being added to sum and click icon autosum
Microsoft Excel... | Answered on Nov 08, 2012
save the file (use save as) before giving a file name under option/tools use a password to protect it
if a sheet is password protected then unless u know the password u cant open it....
i am note sure of there are passwored cracks...look in google
Microsoft Excel... | Answered on Dec 08, 2011
=INT(A1)+0.95
With A1 being the reference to the cell you wish to round up
What that does is first round down the number to a whole one then adds 0.95 to the figure
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Microsoft Excel... | Answered on Nov 03, 2011
Use Picasa. Click here.
Microsoft Excel... | Answered on Nov 28, 2010
Sorry sir MS-Office is not legally available for free download.
You can use Open Office instead. It works just the same and is free.
Download open office from the below link
http://www.filehippo.com/download_openoffice/
Microsoft Excel... | Answered on Nov 25, 2010
You will not be able to legally obtain Microsoft Excel without cost, however you can download and install OpenOffice for free and that includes a component that functions just like Excel and can open Excel documents, as well as Word etc.
http://www.openoffice.org/
Microsoft Excel... | Answered on Oct 30, 2010
enter the number in a cell in XL (i.e. 32568 or 32565 etc etc)
select the cell, right click
chose option - Format Cell
under Number Tab - select "Date"
on the right panel select a Date format of your choice
note - 32568 = 24-02-1989, 32565 = 25-02-1989 etc etc
Microsoft Excel... | Answered on Sep 13, 2010
This is not possible . The algorithm to read the possibilities is about 15 million to one!
The only method you can use is to manually time the information
Please rate my help++++Thanks for using FIXYA
Microsoft Excel... | Answered on Jun 03, 2010
You could try to change the whole workbook font to a known good one or do it a sheet at a time by doing a "select all" then setting the font.
It sounds as if though you are trying to import a web page including the HTML code which may well cause the problem you see.
I prefer to do that type of thing with a
"Get External Data"
"new web query"
which will put things into a sheet in such a way as you can use them in other calculations
Whenever you open the sheet it will go and get the latest information for you automatically so you can then select what you want and copy that to another sheet. to use to keep track of things.
Microsoft Excel... | Answered on Mar 18, 2010
the only solution is that reinstall your Microsoft office then it will ok...
Microsoft Excel... | Answered on Mar 02, 2010
Shouldn't be a date issue... did you open the file the way you normally do ?
Something has changed here... bad shut down with this file opened... maybe.
Open Excel and pull down the File Menu and see if there are more than copy or version of your spreadsheet. Look at all...
File could have corrupted the Font or could be a Virus. Try just changing the font in one cell.
If this is your only copy of the file... make a copy to see if it works on another machine... that will isolate the problem... it may just be corrupt... the fix is Excel healing it on it's own when it opens.
Microsoft Excel... | Answered on Jan 01, 2010
If you have the rest of the Microsoft office programs already installed and running, the number is the same. just activate it in the help dropdown. If you just bought it, the number is with the packaging. If you don't have it, contact Microsoft and they will provide tha number when you register your product. You will need proof of purchase so they know you don't have a pirated copy.
Microsoft Excel... | Answered on Nov 11, 2009
try to restore windows
or use other file recovery software
for small files u can use glary utilities free edition-where file undelete feature is there. you can recover by searching through file undelete option.
if it helps
Rate me
Microsoft Excel... | Answered on Jun 25, 2009
It is possible to do this using the right function.
I created your cells into a worksheet and it is very simple, although I have assumed that the last 3 characters in your cell will be the didigts you need for your formulae.
=RIGHT(B4,3)/1000000
Where the initial text contains more than 3 digits you can adjust for this in the in the formulae with everying else remaining the same.
Microsoft Excel... | Answered on May 22, 2009
I think the excel fine you want to upload on the email is so large that's why it failed to load...
what kind of email provider you using??
the email provider have a limit capacity of file that they allow to upload on the email's..maybe your file exceed the limit that's why it failed to load or to transact.
Microsoft Excel... | Answered on May 20, 2009
As long as your list in Excel is formatted without missing cells in column format with a header in the cell directly above your first list time. i/e if your list is in Column A and you have 500 entries, I am assuming Cell C1 is the column header, and cell C501 is the last item of your list.
An easier way to view items similar would be to go to Data/ Filter and automatic filter.
In the arrow or list format in Cell c1 - select custom, in the pop up box you can filter the contains to highlight smaller elements of your list.
Microsoft Excel... | Answered on May 09, 2009
go to view
there is an icon (full screen) click on that you will get the normal screen back
Microsoft Excel... | Answered on May 04, 2009
Microsoft Excel 2003 (065-03992) for PC Logo
33 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Excel Microsoft
  • Excel Microsoft
Most Popular Question
download microsft excel 2003
  • Computers & Internet
