20 Most Recent
Maytag Ice2O MFX2570AEM 36" 25 Cu. Ft. Freestanding French Door Questions & Answers
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
