20 Most Recent
Good Technology Good for Enterprise Questions & Answers
How to set font size for emails
Settings > General > Text Size.
Slide it as far left as you are blind.
I dont know of a way to increase the size within the actual GOOD applications. I believe it's more an actual phone setting like a windows image would be.
Stuck in starting services
on iPhone 5, double tap home button...
this will show all apps that are "open" (i.e. running in the background). Slide up to force close the application.
Power cycle the phone waiting at least 5 minutes before turning back on.
Re-launch GOOD app.
Re-enter Email and 15 character PIN.
This will restart the services.
On a recently deployment of over 1400 iPhone's this was the most common fix for this error.
The other was a corrupt profile.
Delete user and create new accout, new PIN will be issued.
(I am not nor anyone should ever be held liable for a backup)
Hi I have the Good
The version you are running is fairly old now. After the lastest version are you sill running into these issues.
Good email transmissions are delayed.
Sadly this is most likely a coverage or server issue. You will want to contact your Mobility team or Good Admin at your office. They should be able to look into this delay for you. The only thing you can do on this end is make sure that you are in excellent coverage or on wifi when you try to send the emails. Any other part of the delay will most likely be at your companies server.
In the iPhone Good for Enterprise app, is there a
I don't have an iOS device on me at the moment, but in your general device settings. There should be an option for notifications. And inside of the there is an option for Good. You can disable or customize the push notifications. Also note that due to the iOS freeze states the Good application can't process in the back ground after about 5-10 minutes away from the app. It will still request push notifications on an OS level from the Apple Push servers. But that can be disabled in the above notification settings.
I am using Good for
Hello.
Just some basics: the Good for Enterprise app will not operate without the necessary back-end software.
Please contact your IT administrator for a username and password.
If this problem continues, contact your IT Administrator. Could be a network-related issue.
Hope this helps.
How can I load a movie in iPhone from my pc
easiest way is to load the movie file into Itunes. Then under menu: Advanced is a button to convert movie to IPOD.....
click it
u'll se a converting area appear around where itunes has its devices or store downloads.
once its done converting, make sure ur Iphone sync has movies checked, and select that movie
2/11/2024 10:24:23 AM •
iPhone Apps
Answered
on Feb 11, 2024
