20 Most Recent
Playforge Zombie Farm Questions & Answers
On zombie farm for my
I have the exact same problem! and its incredibly irratating considering i have spent alot of money on this game D:
Always 4% chance for a brain!!!!!!!!!
Personally, I don't have Zombie Farm but chances are that there was a problem when you first downloaded it. Just redownload it from iTunes (it'll be free). Hope this helped!!!
In zombie farm I planted some garlic and it was
Your app might be corrupted. I would suggest uninstalling and reinstalling, although this might erase your save data.
If there is an update for the app try updating.
I would also search guides for the Zombie Farm such as this
guide.
When i returned to the
Just delete the app go to the app store and get it again while it is loading turn off ur device!!
When i try to buy
You can't buy brains in the game store. Buying brains is a pay-for option. Once you are enabled you
buy brains with real money through itunes or through an "in-app purchase" . You need to pay. Sometimes you can get brains buying apps from Clydia. Better earning brains through the game or through Facebook.That is the way the game work.
Here some help. Here a cheat
how to get free brains. That spoils the game the same as buying brains for real not using cheats if money.Better not using cheats if you want to enjoy the game.
Zombie farm app closes when
Welcome to Fixya
Sounds like this is a common problem wih this game either you use it on facebook or from your phone. If you are using your iTouch try to restore it from back up.
Connect iTouch to laptop. Open iTunes > Preferences . Click on Devices and make sure you check the Prevent devices from automatically syncing.
Control click or Right click > Restore from backup. Disconnect.
Do not open game up yet. If you use Game Center, go offline. Open Game and do a manual save. Go online.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I hacked zombiefarm with ifile
You should try a iFile search to locate "1554590" in your market.plist. If that doesn't work, then you can search for any crop, lets say "carrot" and change the exp integer to 1554590 per carrot.
Cannot invade zombie farm every
First try doing a hard reset of your iPhone/iPod touch (press and hold the sleep/wake and home buttons for about 10 seconds, until the Apple logo appears).
Another option is to try disabling GameCenter and/or Facebook in the Zombie Farm options menu.
I cannot invade zombie farm
Zombie Farm uses your iPhone/iPod Touch's system time to count down until the next invasion. You can speed the time it takes for Zombies to invade by setting your system's clock forward until the time of the next invasion.
To do this, go to Settings>General>Date & Time>Set Date & Time
Check the App Store for an upgrade, if there is not one, then remove the App and then re-download it. If that does not help, on the Apps info page in the App Store, near the bottom there is a button to report a problem/bug, click that and let the maker know about the problem, and what device you are using to play it, along with your iOS version.
When I press into the
kindly check your phone memory capacity because other phone will not get started when insufficient phone memory.....if that so try to erase other unimportant games in your phone.
In zombie farm when i
That happens to me too! I think it only lets you invade once a day. I only invade once a day; that usually solves the problem. If it doesn't, either keep trying to invade (this actually makes your zombies hungrier!), or check the app store for an update for the app. My problem is a little different; it only started doing that after I invaded with the maximum number of zombies and then lost one in the invasion.
Good luck!!!!!
