20 Most Recent Crosley Radio Pictograph Slide Negative Scanner 1 ea Questions & Answers
Hi! I have posted a solution to this problem and I hope you find it helpful and accept it.
Acquire Source Failed...Restart DSM
Crosley Radio... | Answered on Aug 24, 2017
What are you installing it on? IF you are putting it on a machine that has operating system like windows 7 or 8, you have the wrong software.
Crosley Radio... | Answered on May 23, 2013
i think that it just does not work i am getting all the same stuff that all of u guys are getting and i have a top of the line computer so its not my computer its this fu**ing crosley scanner its **** i payed a lot for it and i am not to happy why is it still selling if everyone is getting the same stuff over and over not to happy
Crosley Radio... | Answered on Jan 21, 2012
You might have installed the wrong driver for your computer's operating system (OS) version. Uninstall the driver then check the OS version (32-bit or 64-bit). Right-click on My Computer (Computer) then selectProperties.
The system information of your computer will open then look for the system type.
Once the system type is determined, reinsert the driver CD then right-click on the CD-ROM drive and select Explore.
The contents of the driver CD are listed. Open Driver folder then select and open the driver folder for the OS version (32-bit or 64-bit) of your computer. Right-click on the setup.exe (setup) file then select Run as administrator.
The driver will install until a notice is shown that the scanner has been install successfully.
You can address the "Acquire Source Failed..Restart DSM" message by right-clicking on the scanner button at the status bar then selecting Maximize. jan_mczeal_3.jpg
A window will open. Click File and select and click Select Source.
Highlight (Click) the name of the correct scanner installed then click the Select button.
You should now be able to use the scanner.
Crosley Radio... | Answered on Sep 20, 2011
Hi
This type of issues occurs due to unsuccessful installation of drivers or poor USB connection with PC and device. Make sure that the device and PC is firmly connected. Also check the availability of device from the properties in My Computer. If Camera is displaying in the Imaging Devices then the drivers have been installed successfully. If not then you'll need to uninstall and re-install the drivers. Hope this helps...please post back for further assistance.
Daniel
Crosley Radio... | Answered on Jun 29, 2011
You might have installed the wrong driver for your computer's operating system (OS) version. Uninstall the driver then check the OS version (32-bit or 64-bit). Right-click on My Computer (Computer) then select Properties.
Crosley Radio... | Answered on Jun 25, 2011
flash drive or right to computer any ting with usb port
Crosley Radio... | Answered on Jan 05, 2011
There should have been a quick installation guide in the box, if not,the manual is on the installation disc
Crosley Radio... | Answered on Dec 26, 2010
I had the same problem today. I ran Windows "Mr Fix It" and that corrected it.
Crosley Radio... | Answered on Nov 30, 2010
I had the same problem today. I ran Windows "Mr Fix it" and that fixed it.
Crosley Radio Pictograph Slide Negative Scanner 1 ea Logo
26 questions posted
Top Crosley Washing Machines Experts
peter gittos
peter gittos
jdthefixer
Derek Bannister
Derek Bannister
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Washing Machines
Most Popular Question
installed crosley cr5503a
  • Washing Machines
