20 Most Recent LG WT5101H Top Load Washer Questions & Answers
The washer control panel is defective.
LG WT5101H Top... | Answered on Jul 13, 2017
sorry but we need a model number to look it up have you tried a different cycle .
LG WT5101H Top... | Answered on Nov 24, 2015
Check out this website as it may help you.
The Fault has something to do the drive system of the washer. Different model however should be the same. LG WT4870CW error code E6 The Laundry Appliance Repair Forum
LG WT5101H Top... | Answered on Nov 18, 2015
It sounds like the User control and display board inside the machine is faulty.
LG WT5101H Top... | Answered on Jan 07, 2015
Power cut may have blown fuse . If not check mains filter. If that's ok then mother board may be damaged
LG WT5101H Top... | Answered on Aug 12, 2014
Sound like your seals need cleaning and give the machine a wash out with a good cleaner.
LG WT5101H Top... | Answered on Jul 15, 2014
sounds like it has bounced out of balance, it may have lost level, the springs in side might have lost some of there spring, or the clutch may be getting bad. the belt might be loose as well and starts slipping when going faster.
LG WT5101H Top... | Answered on Jan 20, 2014
THIS PROBLEM ARE YOU OCCURRING DAILY? IF IST DAILY ,,THE PROBLEM WITH INLETVALVE,,END OF THE CYCLE FROM THAT WATER LEAKING CONTINUOUSLY,,
you need to call service center for your problem, the unit have problem in pcb board or some switch inside the machine already press by its self.
LG WT5101H Top... | Answered on Nov 02, 2013
I just fixed our WT5101H. It was not draining. The drain pipe, when held down to the ground, would flush out the water just fine, but when it was in the wall drain it did not register. Here's what I did:
Took off the back panel. Located the drain pump and removed it from the base it sits on. I noticed right away than one of the connected wires was completely off. Maybe from the motion of the washer it had removed itself. We electrical taped the wiring to remain snug and presto... we have drainage working again.
I took apart the drain pump to clean it out, and now we do have some leaking since I could not get the unit back together as complete and as sealed... might have to get some caulking or something to keep the little drips away.
Sandi
LG WT5101H Top... | Answered on Jul 04, 2013
pcb is not working
LG WT5101H Top... | Answered on Jan 18, 2013
LG WT5101H Top Load Washer Logo
62 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
e6 error will not wa e6 error lg
  • Washing Machines
