20 Most Recent
Asko WL6532XXL Washer Questions & Answers
I started my machine, an hour later I went back
Replacing the control panel should be the LAST thing you attempt!
Go back to basics first - does the machine empty when you turn it on? have you removed the water in the machine by lowering the waste hose onto the floor or removing the drain filter? do the program indicators light up?is water flowing through the fill hose / hoses? Are any fault codes showing? If you replaced the fuse, did it blow again? Have you any means of testing electrical Insulation / Earth continuity? Have you tried plugging something else into the washing machine socket - say a kettle or heater etc?
It well may be the Electrical Control Board in the end, BUT if you fit a new board onto a faulty part - say a blown heater - you will probably blow the new board as well, and the shop won't take it back for this reason.
Asko WL6532XXl error code LE
Yup, LE is the door latch. Seems like at some point the solenoid gets too weak to push the switch that tells the washer the latch is really closed and it cuts power to the latch and won't operate. The door latch is fairly easy to repair. I've done it twice and I'm just an intermediate DIYer. The latches seem to fail every 3-4 years. You pull the rubber ring and the metal ring from around the door, then undo those two screws you can see around the latch. Then unplug. Then reverse. Unlike many instruction videos for other ASKO models, you do not need to pull the front panel off to do this. Just the rubber ring and huge retaining ring that holds it in place.The confusion right now is finding the parts because no one SEEMS to have them in stock, but they are easy to get, if you don't bother with google to find them, because you won't find them there. Sub Zero has exclusive rights to distribute Asko parts in the US now. So you have to go through them. If you use google you will find "out of stock" and "discontinued" on the listings of everyone else who used to be allowed to sell them. The official distributors aren't google friendly, I guess.If you are in New England, you can get parts from Certified Appliance Parts if you are in the Mid Atlantic you have to go through Mid-Atlantic Parts Distributors. If you are elsewhere, search for "sub zero parts" and your state. The right place should come up.You need ASKO item #3619046410 Door latch It cost me $43.
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Asko W6984 Front Loading Washer Won't Agitate or Spin
No wash agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
mode shifter and or Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
ASKO w6884 Eco vibrate violently when spins
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Asko front loader can I take off hose to use tap
If your dishwasher uses a quick connect hose to the faucet, you can disconnect it while the dishwasher is running ONLY IF the water is shut off and pressure release button is pushed in to release water pressure inside hose. If the dishwasher is calling for water, it will accommodate for a short loss of time. Remember to turn water back on when hoses are reconnected.
