20 Most Recent Bosch Logixx WAS2446 Front Load Washer Questions & Answers
2answers
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
12/14/2020 4:09:27 PM • Bosch Logixx... • Answered on Dec 14, 2020
0answers
BOSCH ERROR F38
Hello what is f38 error?
1/19/2016 7:02:16 PM • Bosch Logixx... • Answered on Jan 19, 2016
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes 3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
1/13/2016 12:45:04 PM • Bosch Logixx... • Answered on Jan 13, 2016
Bosch logixx 8 E57
Circut board of the motor is demeged.if you take out the board witch is next to the moyoryou will see on the electronic print
The demeg.
7/24/2015 4:11:52 AM • Bosch Logixx... • Answered on Jul 24, 2015
What is the best way to resolve my issue
8/11/2014 11:07:59 AM • Bosch Logixx... • Answered on Aug 11, 2014
0answers
0answers
0answers
Bosch logixx 7 door wont open
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
11/3/2013 12:25:15 PM • Bosch Logixx... • Answered on Nov 03, 2013
0answers
Filter on washing machine
down the bottom on the right hand side is a flap,,, open it down and you will be looking at the front end of the pump,, unscrew the plastic screw type and pull it out.. if you cant pull it out after you have unscrewed it ypou will need to tilt the machine on its back and undo the one screw at the bottom near the pump, slide the whole plimpth right and it will clip off,, now undo the 3 screws around the pump,, and the pump will drop down,, you can unscrew it from its housing then empty the **** whats inside it,, then try unscrewing it once all the **** is out... then put it back together the way it came undone.
10/19/2012 9:06:30 PM • Bosch Logixx... • Answered on Oct 19, 2012
Bosch Logixx WAS2446 Front Load Washer Logo
43 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
code nr 0 coming up washing machine
  • Washing Machines
