20 Most Recent
Canon iP2700 Inkjet Photo Printer Questions & Answers
If i print a file,
First, restart the computer and printer to see if that resolves the issue. If not, go to "devices and printers" in the Control Panel. Right click on the printer and select "Use Online". If that option is not available, is this a network attached printer? If so, your router may have assigned a new IP address to the printer. Follow the printer manual on how to find the IP address using the keys on the printer. Then change the printer port settings in your computer to match the IP address.
I have installed Continuous Ink
Press resume button for 5 secs. This works for other canon models using cis.
Thank you for using fixya, have a nice day!
If this helps, please rate me :)
How do i fix my printer?
Try to clean the encoder strip inside the printer,open the cover and clean it with your finger gently.hope it works
I was riffil ink cartridge
After refilling your ink, it may prompt your ink very low... but it is nature there is no problem and effect for that... don worry! All the Canon printer prompt like that.... thanks
