20 Most Recent
Ricoh Aficio Sp 1000sf All-In-One Laser Printer Questions & Answers
I have Printer and Scanner
Hi Mach,
Click on the download link below to goto the driver and software download page of Ricoh.
Download Link
E.g : If I want the printer/scan/fax driver for windows 7, I will click on the download icon under Windows 7 as shown in the image.
Regards,
Shrey
Ricoh Aficio Sp 1000sf AllInOne Laser Printer - Error fuser temp problem
As with all Laser Printers, the fuser temp error can be frustrating. Sometimes, just turning the printer off, then back on corrects the problem. If you've tried this without success, it's time to order a new fuser. Most have been changed to Customer Replaceable Units (CRU)s. The two ways you can tell if that's the case is either the user manual will have it listed in troubleshooting or, open the side of the printer the fuser is on and see if there are finger screws or tabs to release the fuser. NOTE: IF THE FUSER IS HOT, DO NOT TOUCH! YOU WILL BE BURNED!. It takes about 30 minutes for a fuser to cool down to a safe temperature. If you can remove it yourself without tools. Great! Easy take out and replace. If not, a tech will need to come out to remove the fuser and replace it.
I can't believe no one has answered your question until now.
Printer error fuser temp
If it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Fuser temp
Replace the fuser and reset the error code.
Error fuser temp
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Toner empty error
In order for your printer to read the cartridge as full the chip on the toner will need to be replaced/reset. Sadly these cartridges are unable to physically check toner levels and rely upon counting pages/page coverage to estimate.
