20 Most Recent V, Inc. Vizio P46 Television Questions & Answers
Sound no picture
your component cables are mixup check the blue and green wires behind tv
3/15/2015 8:31:30 PM • V, Inc. Vizio... • Answered on Mar 15, 2015
HeMy Vizio P46 started losing
The tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
12/21/2010 6:15:45 PM • V, Inc. Vizio... • Answered on Dec 21, 2010
No picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
10/5/2009 5:53:55 AM • V, Inc. Vizio... • Answered on Oct 05, 2009
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 18 minutes ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 1 hour ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 3 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 7 hours ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 7 hours ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 days ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 3 days ago
2answers
My Telefunken television model TLEDD-42FHDB remote made tv on/off switch flick and remote has stopped working now. Still doesn't work after replacing batteries.
Put the batteries back in and aim the front ot the remote at the front facing selfie camera on a smartphone. Press a button and you should see a flash. If no flash, the remote has failed. If there is a flash, the television IR module or main board has failed.
Telefunken Replacement TV Remote TLED-26FHDPA
Soundtech https://soundtech.co.za > telefunken-replacement-tv-rem... Telefunken replacement remote compatible with TV models: TLCD-29FHDP TLCD-32FHDA TLCD-32HDA TLCD-37FDHA TLCD-37FHDA TLCD-39FHDP TLCD-40FHDC TLED-26FHDPA ZAR 199.00 ..
4/15/2024 10:04:39 PM • Televison &... • Answered 3 days ago
2answers
Venturer KLV39103 10" Kitchen LCD TV/DVD Combo. I need an adapter to change to HDMI for an EVOForce cable box. Where can I buy one.
Question edited for a lot more clarity, full 'make model (what it is)'. There is more to this that meets the eye because your set is analogue and the new cable box is digital. Have a read
Is it possible to modify my kitchen Venturer KLV39103C tv in
JustAnswer https://www.justanswer.com > TV Problems Jun 9, 2021 - Your TV has only one external input and it's an analog coaxial input, hence why the converter and modulator will be needed. 1 answer ยท Top answer: You are very welcome. In my opinion, it would be much simpler to simply j More here https://www.google.com/search?q=venturer+klv39103+convert+to+digital ..
4/14/2024 8:05:32 PM • Televison &... • Answered on Apr 14, 2024
2answers
When I press any button on remote on TV blink red and green light about 15 second. Only working MUTE and VOLUME " - ". THANKS
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean] https://youtu.be/wUpnETSm6_k
4/14/2024 8:03:37 PM • Televison &... • Answered on Apr 14, 2024
Elektra ELCD-3209V Television. What is the price in India please?
9,000 Rupees if you buy 10 Home LCD TV ? 9,000 Bal Traders, Delhi Product Specifications Minimum Order Quantity 10 Or in UAE https://www.amazon.ae/Elekta-Inch-LED-Smart-Black/dp/B07NF1QB63 Elekta 32 Inch LED Smart TV BlackAmazon.aehttps://www.amazon.ae > Elekta-Inch-LED-Smart-BlackScreen size. 32 Inches ; Brand. Elekta ; Supported Internet services. Netflix ; Resolution. 720p ; Special features. Smart. ..
4/10/2024 7:44:16 PM • Televison &... • Answered on Apr 10, 2024
My OVHD Decoder is not responding to the remote. And if I manually switch on not responding. all buttons not responding, but power is there and showing a green light but nothing on the screen
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/
4/10/2024 3:53:20 PM • Televison &... • Answered on Apr 10, 2024
Televison & Video Logo
Popular Tags
4 questions posted
Top V, Inc. Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • V, Inc. Televison & Video
Most Popular Question
no picture flat panel tv sound
  • Televison & Video
