20 Most Recent
Pacific Image PrimeFilm 1800i Flatbed Scanner Questions & Answers
I have not used my
You need to install a
CyberView X scanner driver to use this scanner on Windows and Mac OS X.
On Mac OS X, you need to run VueScan with Rosetta, since CyberView X is a PowerPC program. To do this:
- Click on the VueScan icon while holding the Control key
- Choose 'Get Info'
- Check 'Open using Rosetta'
LOST SOFTWARE / PRIMEFILM1800I
MY TECH MAN WENT ONLINE DIRECT TO PRIMEFILM CO. AND WE DOWN LOADED THE SOFTWARE FOR FREE. THANX FOR YOUR CONCERN ALL IS WORKING NOW.
When I scan, all I get on my screen is a
its one of 2 things, either the drivers are not working properly, or you have a bad scanner assembly in your scanner.
I would recommend trying it on a windows XP to verify if the problem has to do with the drivers. you can also try contacting tech support for your product and see if they have heard any issues with vista and your scanner.
also, just in case make sure your in the right scanner mode, I had one person trying to scan paper, but the scanner was set to scan a negative
thanks di
