20 Most Recent
Pacific Image PrimeFilm 2700 Film Scanner Questions & Answers
VIsta compatibility
Check the manufacturer site!
http://www.scanace.com/en/index.php
The following link shows vista compatibe drivers
http://www.scanace.com/download/drv_pf2700.htm
if you have any problems or questions, post back!
regards,
babb
Scanner head is stuck
see if you are able to openthe cover if you success then use any lubricant oil and apply on scanner head steel rod .
bye
When I scan, all I get on my screen is a
its one of 2 things, either the drivers are not working properly, or you have a bad scanner assembly in your scanner.
I would recommend trying it on a windows XP to verify if the problem has to do with the drivers. you can also try contacting tech support for your product and see if they have heard any issues with vista and your scanner.
also, just in case make sure your in the right scanner mode, I had one person trying to scan paper, but the scanner was set to scan a negative
thanks di
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
