20 Most Recent
Pioneer DEH-P9600MP CD Player Questions & Answers
Unit appears dead .prevously cured with a little
pull the unit out and make sure that your connections are all good and solid -if you wiggled it and it worked momentarily- then chances are the wiring or wiring harness is loose and needs some attention
1/16/2010 1:48:10 PM •
Pioneer...
Answered
on Jan 16, 2010
THE SECOND DISPLAY SCREEN STOPPED WORKING
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
6/30/2009 7:43:15 PM •
Pioneer...
Answered
on Jun 30, 2009
OEL display not working
YOU NEED TO REPLACE A RIBBON CABLE CALL 1 800 421 5080 IS A COMPANY NAMED PACIFIC PARTS THEY SELL THAT PART.
3/19/2009 1:40:27 AM •
Pioneer...
Answered
on Mar 19, 2009
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
2/7/2009 1:54:44 AM •
Pioneer...
Answered
on Feb 07, 2009
Pioneer deh-p9600mp and deh-p960mp
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
1/15/2009 6:36:57 PM •
Pioneer...
Answered
on Jan 15, 2009
Freezes while i press open
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
1/9/2009 5:06:04 PM •
Pioneer...
Answered
on Jan 09, 2009
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
5/27/2008 10:04:06 AM •
Pioneer...
Answered
on May 27, 2008
