20 Most Recent
V, Inc. VIZIO RP56 Rear Projection Television Questions & Answers
Color wheel replacement
The wheel may or may not be sold by itself--Google the model number to see if it has one, and then look at you tube as they have instructions for replacing wheels in several brands.Hint: it may have been made for them by Sharp.
Vizio TV heard lot pop len lhen lost sound and picture but them comes on
l suspect power supply board has failed---someone would have to open and check all voltage going in and out of the board----if outs are missing (any) the board would have to be replaced.If you get it open examine the filter caps on the power supply board to see if any are puffed up on top---the tops are silver and should be perfectly flat with no brown material leaking out at top or bottom.I suspect based on description a component (likely a big IC) failed and they are usually covered with a metal heat sink (plate) so cannot be actually seen---they pop and dead set.
Typical filter cap (capacitor)
The picture stayed on but there was a loud sound
Could be the flyback transformer. The noise comes from the delamination of the layers in the transformer. It's an "old age" thing. You can try slathering it with cyanoacrylate (SuperGlue), but it probably needs to be replaced. Call your manufacturers service agent to estimate costs.
After about 1/2 hour watching tV, the screen
The video board is compromised The reason it takes some time to occur is a heat factor, Once the tranistors that control the picture reach critical temperature they become unstable. The flickering is actually drop out too quick for the eye A halo effect is produced as it tries to redraw the picture at the given line rate, there are light gaps that form this halo effect.
Six years is a long time in todays TV world most start doing this around 2 -3 years just after warranty has expired. Plot? yes I think so given the number we see on here. It can be fixed if you cease to try running it as it will get worse the longer you leave it Estimated cost $2-300
Please rate my helop++++Thanks for using Fixya
Vizio TV low volume
Hi, had this problem and called my cable company who came out and changed some setting ...and now its great.
We have a vizio tv. not even two months old and
You have 3 things that could be cause of no audio
poor solder connections ,Bad capacitors or you need to replace Main Board the one that has cable hookup on it .Encompass Parts 1-800-638-3328
Remote Control Problem
Are Both TVs Vizio TVs? If not it means it has droped the code to the set it is not turning ON
