20 Most Recent
Oritron DVD200 Questions & Answers
Oritron DVD-200 Region Free Fix
Oritron Diamond DVD-200 DVD Player Region Free Fix
Would you like to unlock your Oritron Diamond DVD-200 DVD Player to Region Free?
Follow these steps to unlock your Oritron Diamond DVD-200 DVD Player:
- Press the Menu button on your remote control.
- Press the 9 button on your remote control.
- Press the Open/Close button on your remote control, (note the tray will not open).
- Press the 5 button on your remote control.
- Press the Mute button on your remote control when presented with the region selection page.
- Press the OK button on your remote control when presented with the region selection page.
- Press the Exit button on your remote control when presented with the region selection page.
- The word ALL will appear on the screen and your player will now play discs from any region.
Your Oritron Diamond DVD-200 DVD Player is now Region Free.
I hope that helps.
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
10/5/2017 12:26:12 AM •
Oritron...
Answered
on Oct 05, 2017
Someone please give me the codes for oritron dvd player. I lost the codes for thisvibe axcess 5 in 1 remote. Please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
10/21/2016 2:50:49 AM •
Oritron...
Answered
on Oct 21, 2016
Oritron amplifier has no input ?
Check its powersupply regulator circuit, and main amplifier circuit for any shorted component/s. Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
5/20/2012 1:06:31 AM •
Oritron...
Answered
on May 20, 2012
A DVD is stuck in
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
- unplug the device (dont wanna get electrocuted)
- remove the screws to the back and under the player
- lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
- you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
- remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
4/5/2011 1:06:24 AM •
Oritron...
Answered
on Apr 05, 2011
It keeps cutting off
If you are using the power cord, your power supply is failing or overheating. If it is on battery, replace or fully charge the battery.
8/9/2010 10:21:46 PM •
Oritron...
Answered
on Aug 09, 2010
I have been given a Oritron DVD720 player and the
More than likely you can.
I would suggest looking it up at www.newremotecontrol.com
just look it up by brand and model number and they should have a corresponding remote part number which they sell.
7/28/2009 11:33:23 PM •
Oritron...
Answered
on Jul 28, 2009
My replacement rc-518m remote control is stuck in TV mode how do I get back to a/v
It may be necessary to take the remote apart and clean the contacts with rubbing alcohol and a tissue on the board that is inside. If that doesn't fix it, a replacement is necessary at Ebay.com https://www.ebay.com/itm/394877786274?itmmeta=01HT47X6X7WE749Y2CMG3NX54S&hash=item5bf08cd8a2:g:7pQAAOSwn7BlAn8h&itmprp=enc%3AAQAJAAAA4OMK5%2BdFWZwJQhIS5nEQ3eO7C2zq5QRICeu%2BbPKwqrfkc8con3byi0%2BbabcDYrBTOEyKclvkbzHrOJ1lVMfwduYTPcx0fAcW5XmaZ3ZRWS1%2FnVxMUIwno%2BPNUVuNqN%2FCSDJJ3gG2hQ%2BbGGyfUiO2ppgtjsvtiihnrClntKtSssM8RikHgpG8y9SjAz6z0V0GPkVJf6gypymGRdzz4HfuNn%2BkiMmAXp2NHVWpP6xfbghej%2B1MkOgqhJxV4V1B%2Bp8wVx%2BKV36M%2FVEdzoejZajCMt9ApRe1beW4a0rCXTdGZRuV%7Ctkp%3ABFBM2u70h9Fj
