20 Most Recent 94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert Questions & Answers
2answers
Turn lights flash fast when lights turned on
they are about to go out
12/11/2015 7:05:24 AM • 94 95 96 97 98... • Answered on Dec 11, 2015
2answers
We changed the fuel pump in our 1997 Chevy
Check fuel pressure with a gauge should be up around 50ish if it is look at possibly a bad ignition switch- it may be allowing the pump to run but not allowing power to the ecm/coils. Also check fuse box for blown fuses.
12/11/2015 6:50:20 AM • 94 95 96 97 98... • Answered on Dec 11, 2015
2answers
Whats causing gas to get in the oil
Older engines had mechanical fuel pumps attached to the side of the engine and driven by a push rod. If the diaphragm in the fuel pump failed, gas could get into the engine crankcase and dilute the oil.
12/3/2015 7:16:47 AM • 94 95 96 97 98... • Answered on Dec 03, 2015
How to put quick connect back together ?
Try getting hold of a work shop manual and that should explain how to repair the problem.
10/3/2015 11:08:25 PM • 94 95 96 97 98... • Answered on Oct 03, 2015
97 silverado will start with starter spray but won't stay running
SOUNDS LIKE YOU DONT HAVE ANY FUEL PRESSURE. TRY CHECKING THE FUEL PUMP AND OR FUSE
3/22/2015 5:49:33 AM • 94 95 96 97 98... • Answered on Mar 22, 2015
2answers
Why is there no heat in my 98 chevy Silverado?
The heat control opens a valve at the firewall typically found on the passenger side behind the glove box. If the rod connecting the heat level to the valve is broke, no hot water is directed from engine hotwater to the interior radiator of the truck which heats the cab.
2/25/2015 4:01:02 PM • 94 95 96 97 98... • Answered on Feb 25, 2015
2answers
What does crank sensor look like on a 1996 chevy silverado?
It's just a little plastic piece that sits beside the crankshaft pulley in the front of the engine... Go to Summit racing and you can see one on there site. about $50
1/29/2015 8:24:15 PM • 94 95 96 97 98... • Answered on Jan 29, 2015
No fluid to r/f caliper 96 silverado
A collasped rubber brake hose or your antilock module is blocking that circuit.
9/16/2014 12:05:58 AM • 94 95 96 97 98... • Answered on Sep 16, 2014
Why is the 4x4 lights not working on dash and stuck in 4 low? Need to fix it please help
That means a code is present in the transfer case control module,The acuator on the side of the transfer case gets stuck on GM models .
9/16/2014 12:04:47 AM • 94 95 96 97 98... • Answered on Sep 16, 2014
96 5.0 chevy truck fuel out of tail pipe
You sure it isn't just water condensation from the exhaust pipes..It could smell like gas a little but it probably would run really really rough if it were very much gasoline. Not likely gas.
8/14/2014 6:01:47 PM • 94 95 96 97 98... • Answered on Aug 14, 2014
1995 Chevy Silverado 1500. Running fine and just died going down the road. Still getting fire. Any ideas?
Check the fuel pressure & flow rate at the fuel rail, but FIRST - if you have a "Check Engine" light, have someone get the computer's error codes with a first-generation OBD scan tool.
8/8/2014 12:16:03 AM • 94 95 96 97 98... • Answered on Aug 08, 2014
How do i remove the fan
Need more information. Which fan?
7/17/2014 6:22:55 AM • 94 95 96 97 98... • Answered on Jul 17, 2014
W push on the gas pedl italmost kills the truck
if i understand your problem sounds like the first thing i would look at is the throttle position sensor.
7/8/2014 4:08:10 AM • 94 95 96 97 98... • Answered on Jul 08, 2014
1997 silverado 5.7 calif.I keep getting an IAT sensor error code. I have changed out the sensor and the problem still comes back . Not always right away but within a couple of days my service engine
You didn't mention if this is an OBD I or an OBD II engine control system and how you trouble shoot is different. OBD II is more accurate with more readings given the technician to diagnose. IAT is the intake air temp sensor which is located in the air flow meter housing where the air cleaner connects to the intake plenum on a multi-port fuel injection. If its a OBD I a TBI (throttle body injection) the IAT is in the hose to the air cleaner intake. I will assume this is an OBD I PCM since you say you changed the IAT sensor. The PCM and many sensors will not set a code until engine is warm and in closed loop and may be why the delay after you start it. On an OBD I the PCM will set these codes less often are for shorts or opens in the sensor or wires to the PCM. You replaced the sensor so it may be in the wiring or black ground wire on the top of the eng near radiator hose connection on thermostat housing. Check the connector to IAT for 5 VDC at the plug with key on eng off. When the eng goes to closed loop the PCM grounds all the sensors internally to eng and body grounds outside the PCM. Check black wire on sensor plug to batt grnd or thermostat housing ground for continuity, tight, clean, and no resistance. If it is a constant IAT code then its more than likely a wiring or power problem. If there is no 5VDC to IAT sensor then it can be the PCM is bad or wiring from it. Checking continuity between the 2 wires from PCM will not work, internal diodes and transistors in PCM will be open. Before closed loop the PCM fuel management it programed to simulate a closed choke air flow with more fuel added for cold eng operation and the only sensor in use is the IAC motor, CTS, and TPS. The O2 and other sensors stay ungrounded for open loop. Most I&M test machines check for check eng light and will not continue its test until the CEL stays off. Hope this helps, bob
12/24/2013 2:18:32 PM • 94 95 96 97 98... • Answered on Dec 24, 2013
2answers
Idles high all the time
are you throwing a code ? if not try checking your "idle air control valve". if its not that, you may have a slight vacuum leak somewhere.
11/15/2013 2:51:00 PM • 94 95 96 97 98... • Answered on Nov 15, 2013
Hard starting, new battery, starter good
Are you saying it cranks three times, then starts ?Have you checked fuel pressure before and after cranking ?
7/21/2013 2:57:18 AM • 94 95 96 97 98... • Answered on Jul 21, 2013
2answers
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM • Chevrolet... • Answered on Sep 09, 2022
Drum brakes 1998 s10
What is the question?
11/25/2018 2:32:16 AM • Chevrolet... • Answered on Nov 25, 2018
Torque specs 05 Chevy Silverado 1500 4WD front hub assy and axle nut
165 ft lbs
11/25/2018 2:26:57 AM • Chevrolet... • Answered on Nov 25, 2018
94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert Logo
16 questions posted
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Vehicle Parts & Accessories
Most Popular Question
turn lights flash fast when lights
  • Vehicle Parts & Accessories
