20 Most Recent
Minolta DiALTA Di350 Laser Printer Questions & Answers
Codice c0500
Sir/mam,
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Error c1038
The system fails in checking initial engine connection. When the Power Switch is turned ON. #2 The system succeeded in checking initial connection when the Power Switch was turned ON; then it
fails in rechecking initial connection through the execution of a software reset when a communications error occurs during operation.
1. Check the connection between Master Board and MFB2 Board.
2. Reset the malfunction and turn OFF and ON the Power Switch.
3. Change MFB2 Board. Change Master Board.
So will check each connector to each board, one at a time check for a bent pin pins are on the board connector. then re-seat each connector properly, worse case bad control board, doubt you can find a board a very old legacy Minolta Machine, try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
We have a Minolta Di552
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors. Btw, I’m available to help over the phone in case u need at
Machine trouble c0501
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to fix error code C00500 on dialta 350
