20 Most Recent
Action Drift HD 170 High Definition Camera Questions & Answers
I have bought a Drift
Read Page 15 on the manual , but first of all use always in priority the updated software from internet, last but not least for many people remarkable also the importance of the update of the firmware to get the best adjusment possibility very important to know the right model AND important the revisionnumber belong to it of your product and read carefully before firmwareupdates beware firmware is a different link right behind the first link https://onboardvideo.com.ua/download/hd170-user-manual.pdf
Firmware
Hd170 Problem... Camera says no sd card but there
I had the exact same problem. I took the camera apart, adjusted the height of the gold plated spring connectors inside the SD card slot, and re-flowed all of the SD card slot solder joints. The camera is now working good as new... Good Luck!
Dragon Vision 3 Pro Action Camera will not power on with good battery.
Sure, here are some troubleshooting steps you can try:
- Test the battery: Use a multimeter to test the voltage of the battery to ensure that it is actually providing the proper voltage. If the battery is not providing the proper voltage, it may need to be replaced.
- Check the power button: If the power button is stuck or not functioning properly, it could prevent the camera from powering on. Check the power button to ensure that it is working correctly.
- Inspect the circuit board: If the camera has been dropped or otherwise damaged, it's possible that there is a problem with the circuit board. Inspect the board for any signs of damage or loose connections.
- Update firmware: Check if the camera has firmware updates available, and if so, update the firmware as this could solve the issue.
- Replace components: If none of the above steps work, it may be necessary to replace the camera's power supply or other internal components. .
Owners manual
If you mean Itek
action pro sport camera,
there are several links if you search on Google
I am setting up a Vision 1 action camera DragonTouch 1 for my grandson. How do I format the SD card that I purchased for tllhis?
Most SD card will fit in your laptop or tablet with an adaptor sleeve. Most laptops today automatically format new memory cards or prompt you to do so. Look on the side of your laptop or tablet for a hole about an inch by 1/8 of an inch slot. Insert the sleeve and follow the instructions. You can go old school and use the command prompt window and drive letter using the command help from the C:>
type help from the C prompt to see the proper commands
example
C:>format D:
or
C:>format E:
etc..
***make sure you have the correct letter or you will clear all the data from whatever letter you use.
