20 Most Recent
Sony CyberShot DSCS750 Digital Camera Questions & Answers
All my photos are so bright
Check to make sure your Exposure Compensation is not set to a positive number, usually referred to as E/V +-
If it is put it back to 0
If it is already at 0 you can set it to the minus side which will effectively reduce your camera's exposure(darken your photos).
Good Luck
Does my Sony Cyber-Shot DSC-S750
The camera does not have a feature for stamping dates onto the photographs, but the information is stored with every picture. Just about any photo viewing program should be able to display it. Depending on the program and printer, you can choose to print the date on the picture, in the margins, or on the back. Please refer to the documentation for whatever program you use to print.
My digicam lens keeps on
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
SONY DSC-S40 RESET IT SELF.
If you have already cleaned the lens gears and the issue persists, it is possible that the lens electric motor is not working properly. You can try resetting the camera to see if it helps. Here are the steps to reset the Sony DSC-S40:
- Turn off the camera and remove the batteries.
- Wait for a few minutes before reinserting the batteries.
- Turn on the camera and see if it works.
If the camera still does not work, it may be a hardware issue and you may need to take it to a professional repair service or contact Sony support for further assistance.
2/26/2023 2:52:49 PM •
Sony Cameras
Answered
on Feb 26, 2023
