20 Most Recent Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Questions & Answers
2answers
Bad power/LED board in Samsung UN39FH5000FXZA, Version PF03?
Yes. the ballasts are combined so you'll have to get that board. Shopjimmy has a repair service or you can get a new board from them. TV Parts Universal TV Stands DLP Chips ShopJimmy
11/8/2019 2:43:24 AM • Samsung... • Answered on Nov 08, 2019
6answers
Have a Samsung UN39FH5000 LED TV (a refurb that's out of warranty). Last week the screen went out....still hearing audio, but the screen is completely black. Neither the "welcome" screen, nor any menu
Can you see a faint picture when looking up close to the screen? If so this could be the screen inverter that lights up the screen that has gone!
2/16/2018 10:45:17 AM • Samsung... • Answered on Feb 16, 2018
0answers
How do I fix a samsung un39fh5000f tv which has standby light, and has standby voltage at the cable leading to the main board, but won't turn on?
Take the rear cover off the tv, then look for swollen or enlarged capacitors on the power board. You can desolder the bad ones out, then re solder new ones in. It may sound like a difficult task, but it is pretty easy.
10/7/2016 12:08:24 PM • Samsung... • Answered on Oct 07, 2016
Display went dark/black- symptoms point to T-con board but after 20 minutes, display lit up for 2 minutes then went dark again. Same thing happened again after next 20. After 60, display stayed on
Hi there, I was a Samsung tech for 3 years, and T-cons are a common problem. But it sounds like a loose wire to the T-con, I have came across the same issue in the field. I would break it apart and look for a loose connection. Thanks, Jason If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
8/2/2016 6:59:14 PM • Samsung... • Answered on Aug 02, 2016
Samsung un39fh50000fxza no picture or sound. Took off back panel plugged in and flashing white light is all that happens. Any answers?
The power supply board is not developing all the necessary voltages that supply all the other boards in the TV.
6/19/2016 10:45:16 PM • Samsung... • Answered on Jun 19, 2016
0answers
0answers
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
11/13/2015 7:58:32 PM • Samsung... • Answered on Nov 13, 2015
0answers
How do I fix samsung tv no picture just sound
Since you have replaced the LED board and you can still see a faint menu screen, this would indicate the LEDs have blown! Replace the backlight LEDs.
7/7/2015 4:54:25 AM • Samsung... • Answered on Jul 07, 2015
Am I able to set a time to turn on and off this television? I like to fall asleep watching TV but want it to turn off once I have fallen asleep.
This television does come with a timer feature that can be used to turn the TV off at a predefined time.
2/16/2014 1:25:37 PM • Samsung... • Answered on Feb 16, 2014
Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
20 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
bad power led board in samsung
  • Audio Players & Recorders
