20 Most Recent ASUS Eee PC 1215NPU17BK Netbook Questions & Answers
0answers
Battery won't charge
3/22/2014 2:04:12 AM • ASUS Eee PC... • Answered on Mar 22, 2014
Cant start after BIOS update
It sounds like the boot sector on the hard drive and a bypass of the Bios. Pull the hard drive and try to set the BIOs. See if that works for you.
2/26/2014 11:39:26 PM • ASUS Eee PC... • Answered on Feb 26, 2014
0answers
Hi there, The little pc's screen
Yes there is a ribbon cable that connects to the back of the monitor, but as a rule, if that cable is loose you lose the monitor all to gather Was the laptop dropped, jarred, fell over on the screen, with the lid closed? Has a driver been updated resently? I had a similar issue but thr monitor was dark no connection, I accessed the rear of the monitor, and reseated the ribbon cable, and secured it with tape. Your problem sounds different like a software issue. You have tried to reboot? remove battery before, plugging the AC in.
11/10/2012 9:28:59 PM • ASUS Eee PC... • Answered on Nov 10, 2012
WANT TO REMOVE THE USER NAME AND PASS WORD. WANT TO ALSO FIND OUT HOW THING ARE USED
boot in safe mode and goto control panel then click users, What do you meen how things work?
2/15/2012 4:55:42 AM • ASUS Eee PC... • Answered on Feb 15, 2012
HDD not detect with win xp instalations. Cannot
Before you downgrade operating system you should enter bios setup.
turn on >>> press DEL key repeatedly
On Hard drive section >>>change AHCI to IDE >>> save and exit
you can start install win xp.
Note : to upgrade to win 7 do reverse
akee.4shared.com
8/15/2011 6:23:57 PM • ASUS Eee PC... • Answered on Aug 15, 2011
2answers
Wd 11 error code:0xc0000034
The last line of your error message contains the solution: "You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer." Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM • ASUS Eee... • Answered on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM • ASUS Eee... • Answered on Oct 07, 2019
2answers
I recently purchased an Asus
Hello Machatsiduba, It's likely that the network card is capturing some radio signals phones close to your geographical location. Specifically, the Wi-Fi controller can cause this problem; I recommend you follow these links to solve this problem. 1) https://support.microsoft.com/en-us/help/4000460/windows-10-check-wi-fi-drivers-settings 2) https://support.microsoft.com/en-us/help/4000461/windows-10-wifi-problems-home-layout
5/25/2019 12:13:46 AM • ASUS Eee... • Answered on May 25, 2019
Rog 750 g750jw serial location
x2. the ASUS box has a white sticker on the new box. clearly showing this fact. the motherboard, has sticker to ,for the same thing, same answer, in the BIOS info screens, the serial will bet there and a UUID, serial, that Microsoft uses, to block activation. there a mAC too. you did not say why you need this, so lacking context we guess. omg a gaming laptop... ASUS Rog 750 g750jw on laptops in general, its on the bottom of the case on some remove the battery pack and its a sticker inside there. on newer laptops, the deleted stickers (deemed ugly) so is deep hidden. BIOS pages are it. i look at your mobo, and see only stickers on the ram slots so open the ram hatch and look? I SEE ONLY THIS. i redacted it a bit, to make it neutered. PN: not this. PT? i guess not. lower right, side is my guess, on SN. 69N-bla bla sn-rog-lf2mtn200wr504vgnybkj5cw-1-0.jpg
11/5/2018 1:26:46 PM • ASUS Eee... • Answered on Nov 05, 2018
Call Asus support, or info could be in the manual
11/25/2017 7:53:51 PM • ASUS Eee... • Answered on Nov 25, 2017
My Asus Eee netbook keyboard will suddenly for no
see if you can find out why at this link... Asus Eee netbook freeze up Google Search
10/21/2017 1:03:24 PM • ASUS Eee... • Answered on Oct 21, 2017
I was running avast anti-virus while browsing using chrome when I tripped on the power cable and the system shut down. the next time I turned the power on, I got DISK READ ERROR OCCURRED PRESS CTRL+AL
Hello, Weird problem... situation may have nothing to do with what happened. Your hard drive may have core problems. I would run the BIOS diagnostics if able. Also, boot from the OS install DVD and get to a command prompt where you can run CHKDSK. Good Luck, Steve I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
9/30/2017 3:58:53 PM • ASUS Eee... • Answered on Sep 30, 2017
0answers
Asus keyboard typing * instead of p
one or more keys may be stuck
10/25/2016 1:28:01 PM • ASUS Eee... • Answered on Oct 25, 2016
ASUS Eee PC 1215NPU17BK Netbook Logo
13 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
hdd not detect win xp instalations
  • Computers & Internet
