20 Most Recent
Panasonic Toughbook CF52 Notebook Questions & Answers
Panasonic CF 52 Toughbook Windows XP install
If you choose to install Windows XP on the Panasonic CF52,
then please either order the original recovers DVD directly
from Panasonic, or if you wish to re-install from scratch yourself,
please use Windows XP SP3 (service pack 3) and NOT SP2.
You will find the drivers here:
Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
You can even re-install with this XP SP3 CD:
Just make sure to use your Windows XP COA license located
on the back of the Panasonic Toughbook which looks like this below
Good Luck to you and Regards from:
Richard, Montreal Based Panasonic Canada Toughbook
Authorized Dealer since 1989.
2/5/2018 4:10:04 AM •
Panasonic...
Answered
on Feb 05, 2018
Install xp
To install Windows XP on a Panasonic Toughbook CF52
you have two choices:
1) Use a standard Win'XP Pro SP3 boot CD and then
then download each driver from the Panasonic Website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
2) Purchase the recovery disk from Panasonic directly
from the following website:
http://business.panasonic.com/support-computerstablets-dvdrequests
Here is what they say:
Recovery DVDs are available by mail for select Toughbook® products. Windows® XP back up service is only available to customers who purchased Panasonic computers with
XP downgrade rights. Windows XP Backup Image and Windows 7 Recovery DVDs restore a PC to its original factory image. The standard Panasonic factory image includes the Windows operating system and all drivers/applications originally installed by Panasonic.
That is it.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
2/18/2016 4:33:44 AM •
Panasonic...
Answered
on Feb 18, 2016
Wireless drivers CF-52PF9BXQP
The Drivers for all Panasonic Toughbook
Models are availoable on this website:
The CF52P is a MK3 model and drivers are available
for either Windows XP, Windows 7 32-bit or 64-bit.
Please refer to the website and you will find the
correct drivers that you are looking for.
Good Luck!
Regards,
2/16/2016 5:15:40 PM •
Panasonic...
Answered
on Feb 16, 2016
Sceen freezes
Possibly a bad video driver or video card error. Bring it to a local shop for more in depth information
11/19/2013 12:32:25 PM •
Panasonic...
Answered
on Nov 19, 2013
Network Controller
Dear Keith,Could you please clarify your problem? What kind of control do you need for your network? Show how many PCs are connected to your network? Block your ports? Sniff messages inside the network? Providing us with more details would help us find the best solution for the problem mentioned.Regards,Miguel L. Martins
11/3/2013 6:36:05 AM •
Panasonic...
Answered
on Nov 03, 2013
CF-52 V Drivers
We couldn't really identify which drivers are missing. Here's what you can do. Boot to safe mode and check the device manager. Uninstall the drivers with problems and restart your computer. After that, install the drivers by going to the website of the manufacturer and download the drivers from there. Use RadarSync if you want to update the drivers. This software is an automatic PC Updater (Drives). David
4/4/2013 4:38:19 AM •
Panasonic...
Answered
on Apr 04, 2013
I have a Toughbook CF-52
The beeping noises occur when the laptop has been running for Several minutes?
This means that the temperature sensor on the CPU has reached the warning threshold, as set in the BIOS/CMOS of your laptop computer. It is getting too hot, ensure that the computer is slightly raised off the work surface to allow greater airflow through the computer system.
Also try and remove as much dust as you can from the CPU cooler of the laptop, the vent is usually located on the right side. Use a vacuum cleaner, the laptop should be powered off when cleaning it.
The beeping noise is a warning signal and not the problem. It is an indicator of the problem.
Take care!
damnor01
6/9/2011 2:19:49 PM •
Panasonic...
Answered
on Jun 09, 2011
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows:
Hold down the "CTRL" and the "ALT" keys and while holding down
these two keys press the "UP Arrow" key and then release all
three keys. This will reset the screen so it is right side up instead
of upside down.
Good Luck and regards from:
Richard, Authorized Panasonic Canada Toughbook Dealer since 1989.
P.S. The arrow keys look like this: The up arrow is the one on the top
4/6/2018 5:40:18 PM •
Panasonic...
Answered
on Apr 06, 2018
