20 Most Recent Candy GOY105 Front Load Washer Questions & Answers
Why does our smeg washing machine keep having an e05 error?
https://www.youtube.com/watch?v=kzhlvB2LjXg here is a link that will help you
11/28/2014 10:26:19 PM • Candy GOY105... • Answered on Nov 28, 2014
How can I Cancel a spin
turn off the mains or press start stop
11/28/2014 10:25:31 PM • Candy GOY105... • Answered on Nov 28, 2014
0answers
Error codes
Be the first to answer 11/20/2013 9:43:56 AM • Candy GOY105... • Posted on Nov 20, 2013Be the first to answer
I have a Candy Go
Were you able to check the operation of the pump itself?
If not following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
9/19/2011 3:34:27 PM • Candy GOY105... • Answered on Sep 19, 2011
0answers
I started a wash cycle
try unplugging- let sit for an hour- and plug back in
7/30/2011 1:59:44 PM • Candy GOY105... • Answered on Jul 30, 2011
New machine and delicate light keeps flashing
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
7/16/2011 2:07:05 AM • Candy GOY105... • Answered on Jul 16, 2011
Hi my machine goes so far through a wash, then
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
John C
6/14/2011 6:23:50 PM • Candy GOY105... • Answered on Jun 14, 2011
Hi i have candy go washing machine it shows error
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudimentary understanding of the mechanics of a washing machine.
1/8/2011 12:11:01 PM • Candy GOY105... • Answered on Jan 08, 2011
2answers
My candy washing machine incidates aquaplus button blinking between 5 min maching working!! why is behave like that
Candy Washing Machine
  1. Push and hold the FIRST Option Button with LED top right.
  2. Turn the Program's Selector Knob 2 clicks clockwise.
  3. After about 5 seconds, release the FIRST Option Button.
  4. If the previous procedure was correctly carried out, all LEDs are turned ON simultaneously.
  5. Press the START/PAUSE Button to start the self test mode
3/8/2024 11:51:34 AM • Candy Washing... • Answered on Mar 08, 2024
The start/pause button is not working on my candy smart class a washing machine
the pump is blocked up or the filter once you take the blockage you need to reset the machine too do this turn off the mains power press and hold usually the start pause or menu button and turn the mains on wait a few seconds and let go should clear the fault detection if it is the filter or a blocked bad pump and its clear then the machine will reset
2/13/2024 11:34:27 AM • Candy Washing... • Answered on Feb 13, 2024
The start/pause button isnt working
I have always found that my Candy refuses to function at times, especially if I have tried to set it with wet hands. Do a Master Reset. Switch the circuit breaker off. Wait for 60 seconds. Turn it back on. Open and close the door 6 times within 12 seconds. I know it sounds mad but it works.
12/27/2023 12:30:18 AM • Candy Washing... • Answered on Dec 27, 2023
Candy GOY105 Front Load Washer Logo
28 questions posted
Top Candy Washing Machines Experts
Kolbrun...
Oliver Street
ADMIN Andrew
ADMIN Andrew
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Candy Washing Machines
Most Popular Question
candy go
  • Washing Machines
