20 Most Recent
Roland Gr33 Guitar Synthesizer Questions & Answers
Guitar out has no sound
You must connect a short jack cable between the GK2 or GK3 and you normal guitar jack out. Secondly, the switch on the GK should be in the middle, that will give synth & dry guitar simultaneously.
Which system do I need
You could hook the output of the GR33 to something like an AKAI MPC (http://www.akaipro.com/mpc) assigning different notes to trigger different samples or sequences.
I just bought a used
Hi daveihde,
Can you please elaborate , what you meant by freaked out?
This is to confirm whether the device is actually playing the sawtooth waveform in a way that is abnormal or it's normal for this model to play sawtooth waveform sounds in that manner.
Please compare it with an identical device and then find out the difference , sometimes a good servicing , a cleaning of the circuit will help you out to solve the problem, in addition to system reset.
Hope this helps ..:)
I my gr 20 is only picking up e a d g b and not
If you want help from Roland you will have to register:http://www.rolandus.com/backstage/login.php That will get you access to full support and their email address. I think you are having problems with your GK-3 pickup. Make sure your string that you are having problems with is the optimal height etc. The adjustment for the GR-20 is in the manual at this link:http://www.roland.co.uk/assets/media/pdf/GR_20_Q_A.pdf Make sure your pickup is installed correctly and adjusted properly first. The manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811530/GK-3_e11.pdf If you have everything adjusted and only one string is not working then I would guess you have a cable problem and the best thing is to contact Roland for advice. I didn't walk you through the adjustment because every installation for every guitar is different. Hope this helps.
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
