20 Most Recent Craftsman Sears Liftmaster Garage Door Opener Safety Beam Sensor Kit 41a5034 Questions & Answers
After a power outage, my remotes don't work. The keypad and button inside the garage work fine. I took. The batteries out for 30 seconds and unplugged the receiver too. What do I need to do?
[PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
www.liftmaster.com/.../en.../tucmanuals/114A3044.pdf Chamberlain GroupThe Chamberlain Group, Inc. 845 Larch Avenue. Elmhurst ... Please read this manualand the enclosed safety materials carefully! ? Fasten the manual near the ...
9/3/2015 1:47:40 AM • Craftsman Sears... • Answered on Sep 03, 2015
When the door opens it slams into the unit I did adjust it almost all the way out and it still slams
Are you sure you are adjusting the limit controls and not the force controls.. depending on the age of the opener the limits controls are on the side and the force controls are on the back and they are blue. If you are adjusting the limits and nothing is changing you then either have a bad limit rack or circuit board. I just changed out a rack a little bit ago.
3/6/2015 8:39:46 PM • Craftsman Sears... • Answered on Mar 06, 2015
2answers
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES. THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY. YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY). BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
1/1/2015 9:33:47 PM • Craftsman Sears... • Answered on Jan 01, 2015
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
12/23/2014 3:31:02 PM • Craftsman Sears... • Answered on Dec 23, 2014
2answers
How to fix a garage door which remote opener does not work?
Hi, Check the beams (Lasers on each side) are aliened correctly easy to do they are on soft metal supports that can be tweaked effortlessly. http://www.liftmaster.com/lmcv2/service/manuals/ Good Luck
12/16/2014 12:54:58 AM • Craftsman Sears... • Answered on Dec 16, 2014
How to reset garage door opener?
Phone number for customer service is usually poste on opener motor housing. Call them they will walk you thru the procedure, simple to do.
11/15/2014 8:13:51 AM • Craftsman Sears... • Answered on Nov 15, 2014
How do I remove a sears garage door wall switch
Disconnect electrical power, remove switch cover unscrew switch from wall.
11/15/2014 8:08:43 AM • Craftsman Sears... • Answered on Nov 15, 2014
My Craftsless GDO will let me program only 1 remote or keyless entry at a time. I purchased a "NEW" logic board and installed it. Still have the SAME issue.
WHEN YOU PROGRAM THE FIRST REMOTE YOU CLEAR THE CODES BY HOLDING DOWN THE BUTTON FOR 30 SECONDS. THEN PRESS AND RELEASE THE BUTTON, HOLD DOWN THE REMOTE BUTTON FOR 20 SECONDS OR UNTIL YOU HEAR A CLICK. WHEN YOU PROGRAM THE SECOND REMOTE DO NOT HOLD DOWN THE PROGRAM BUTTON. JUST PRESS AND RELEASE THE BUTTON. HOLD DOWN THE REMOTE BUTTON FOR 20 SECONDS OR UNTIL YOU HEAR A CLICK. YOU CAN PROGRAM UP TO 10 REMOTES ON SOME OF THE NEW OPERATORS. IF YOU HOLD DOWN THE PROGRAM BUTTON IT ERASES ALL CODES AND YOU HAVE TO START OVER. HOPE THIS HELPS STEVE.
10/17/2014 4:43:34 PM • Craftsman Sears... • Answered on Oct 17, 2014
0answers
1047 code
Be the first to answer 7/17/2014 3:04:39 AM • Craftsman Sears... • Posted on Jul 17, 2014Be the first to answer
Where can i find a Ac adapter p/n aa2420-7 for a
Sears or e-bay.
6/15/2014 1:38:29 AM • Craftsman Sears... • Answered on Jun 15, 2014
Sensors are not working.
Ensure the sensor beams are perfectly aligned and no objects in the way. Clean lens on both.
6/15/2014 1:29:36 AM • Craftsman Sears... • Answered on Jun 15, 2014
I have a Sears Craftsman 1.5 hp garage door
Timer should be on the back of the main unit with the lights. Turn adjustment to off or to 1 of the timer settings.
6/15/2014 1:27:48 AM • Craftsman Sears... • Answered on Jun 15, 2014
I had to manually close my craftsman garage door
Look for a red handle with a rope attached along the bar from the main unit to the door. Pull this handle and release until it engages the track again.
6/15/2014 1:25:26 AM • Craftsman Sears... • Answered on Jun 15, 2014
Owners manual for model 139.53300 garage door opener
Call Linkmaster's 800 phone number.
6/15/2014 1:22:46 AM • Craftsman Sears... • Answered on Jun 15, 2014
Garage door will not fully open
The back of the main control panel/light assembly has adjusters to set up stop and down stop, use a small flat end screwdriver to adjust.
6/15/2014 1:21:55 AM • Craftsman Sears... • Answered on Jun 15, 2014
Light flashes 10 times when trying to close door
Align light sensors
6/15/2014 1:16:47 AM • Craftsman Sears... • Answered on Jun 15, 2014
How do you change the passcode on a keyless garage door opener?
There are buttons on the rear of the main unit to do this.
6/15/2014 1:15:58 AM • Craftsman Sears... • Answered on Jun 15, 2014
Theres a bussing noise coming from the pad in the garage. its a craftsman garage door .
Try re-adjusting the up stop and down stop points.
6/15/2014 1:11:29 AM • Craftsman Sears... • Answered on Jun 15, 2014
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
6/15/2014 1:05:03 AM • Craftsman Sears... • Answered on Jun 15, 2014
Craftsman garage door opener will not complete a cycle
Beam Sensor must point at each other and nothing between them to stop the beam and the lens must be clean . I had one of the PW boards have a cold solder joint and I had to buy a new sensor. Hope this gives you some ideas B. J.
4/10/2014 6:49:23 PM • Craftsman Sears... • Answered on Apr 10, 2014
Craftsman Sears Liftmaster Garage Door Opener Safety Beam Sensor Kit 41a5034 Logo
Popular Tags
48 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
sears 41a4315 7e garage door opener
  • Garden
