20 Most Recent
Disney DT1350-C 13" TV Questions & Answers
Sound won't work on my Disney dvd/tv combo
Either the speaker is bad or broken wire OR more likely the headphone jack is the issue---when jack comes out it lets a leaf in the socket engage the speaker back----when used a lot the jack causes no sound.
How do I get the TV in video mode
There should be an "input" or "source" button on the remote. If you press this a couple of times, you should eventually get to the video mode, if not right away.
I hope this helps!
Der Strom
Replacement parts for DT1350C
I just found the owner's manual online. I knew where mine was until the last move. There is a phone number on the back of it to call for parts and accessories. 1-800-321-6993
They are available every day from 9:30 amd until 5pm.
I am going to try tomorrow and hope to order speakers.
Remote
as it works fine with dvd means it looks ok
you can do one thing you tune tv from font panel of tv if it works ok then problem in remote & if it does not then problem in tv.
better you reset tv once & then check
if you wanr more details try given web site
http://www.remotes.com/
