20 Most Recent
Copystar Ri-4530 Printer Questions & Answers
How do i reset Error code C6020 on a Kyocera 8030 copier
This code is a high temperature in the fuser unit. The reset process is as follows, enter 1087-1087-163-print button-execute-print button then shut machine off when the message comes up on the display. The machine should clear the code and reboot, if the code returns you will need to contact a service company for further assistance. Hope this helps.
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
1135
Paper jam in the paper cassette
