20 Most Recent
HEWLETT-PACKARD EliteBook 2540p XT931UT Notebook Questions & Answers
I have HP elitebook 2540
To reset the BIOS password read the information from this
link.
In case of your HP Elitebook laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
How can i reset Cmos password for Hp EliteBook 2540p
You might try this, although it might not work on your specific model as some Elitebooks keep the password even if these steps are followed. http://h30434.www3.hp.com/t5/Notebook-Display-and-Video/Reset-BIOS-Password-EliteBook-8540w/m-p/927235#M30136
Got 2540p fn key not
try using usb keyboard. if fn key working. it mean you have to replace the keyboard.
Conect to tv
Use a cable (HDMI, VGA), select the TV's input, cycle your laptops' display mode (laptop, external, both).
Is there a way to disable the touch sensitive strip on hp eelitebook 2540p?
Shutdown your Notebook completely and once you Power ON the Notebook, Keep Pressing F10 key repeatedly to load BIOS screen on your Notebook.
In BIOS screen, navigate to System Configuration(on top) and then you would find Boot options. Under Boot Options there would be an option to Enable/Disable QuickwebDoes that help.
How to remove BIOS password on hp elitebook 2540p
some Elitebooks keep the password even if these steps are followed. Try this linkhttp://h30434.www3.hp.com/t5/Notebook-Display-and-Video/Reset-BIOS-Password-EliteBook-8540w/td-p/927153
Computer will not connect to wireless network
Do you have the physical wireless switch on?Can you see the list of available networks?Do you get error messages when attempting to connect?Is it your own network your connecting to or a public?Have you checked in Device manager to ensure no issues with your wireless driver?Is it appearing to connect but not working? (Check your config from a cmd prompt and type "ipconfig" do you get a 169.x.x.x ip or a 192.168.x.x ip if the first your router/computer is having issues handling dhcp. Reboot the router and computer.
