20 Most Recent
Lexmark Wheelwriter 35 Series II Typewriter Questions & Answers
How to remove batteries in
Slightly lift the battery case and slide it out pop the batteries out, if they are corroded clean the contacts with sand paper and reinstall.
DickyO
6/23/2011 4:59:05 PM •
Lexmark...
Answered
on Jun 23, 2011
Lexmark wheelwriter 35 "lo-bat" message
Ther is a battery holder Just to the L. or R. of the PC board onthe base of the machine, it takes 2 0r 3 AA batteries. Be sure you clean any corrosion off the contacts.
DickyO
2/14/2011 5:16:36 PM •
Lexmark...
Answered
on Feb 14, 2011
When typing a card the
First spray some WD40 on the silver shaft that the carrier slides on. The with the machine off slide the carrier back and forth it should move freely if not look for debris inside the T/W.
you should be able to type thru the R. margin it only beeps.
DickyO
2/8/2011 4:12:06 PM •
Lexmark...
Answered
on Feb 08, 2011
Help! I cannot get
DL PRT ca be turned off with the print mode key on the R. side of the keyboard.
The batteries need replaced. They are located just beyond the keyboard on the base, 2 or 3 batt. on either the L. or R. of the PC board. Be sure to clean the contacts in the holder.
DickyO
12/8/2010 5:48:39 PM •
Lexmark...
Answered
on Dec 08, 2010
I turned off the lexmark,
The 121 indicates a keyboard problem.The rt. keyboard connector has 7 connectors bussed together some of them
become open. Cut a piece of foil wide enough to cover just those
connectors and slide it down into the plug over just those 7 connections
and this save replacing the keyboard.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
10/15/2010 11:27:49 PM •
Lexmark...
Answered
on Oct 15, 2010
The vertical row with letters
The keyboard is bad. Contact Geo. Beyers Co. @ 800-392-8085 for a keyboard rebuild, tell them O'Reilly sent you.
DickyO
9/27/2010 4:57:03 PM •
Lexmark...
Answered
on Sep 27, 2010
215 error
215 is a printwheel error. Remove the printwheel, look for debris in that area, if you have a compressed air source blow out the P/W area, reinstall the P/W. If you still have the problem the LED sensor is probably bad.
DickyO
9/10/2010 6:06:32 PM •
Lexmark...
Answered
on Sep 10, 2010
How do I store information that is to be printed
First be sure the lo battery is not on the display. On the L. side of the keyboard are 3 keys save, play and del, Hold down save while entering an address 01-99, release save key type info., press save again. Tto replay hold the play key and type address. To delete use the same process. If the batteries or the battery holder are bad all will be lost when the T/W is turned off.
DickyO
11/20/2009 5:07:08 PM •
Lexmark...
Answered
on Nov 20, 2009
How do you save margins and save information to
First thing is to be sure the batteries are good and the holder is clean. If there not you will get lo batt on the display and everything you put in will clear when you turn it off.
To save something Press store and an address 01-99 type info when done press store again info. is stored. to print press play and the address. To delete use del and the address.
DickyO
11/19/2009 5:55:38 PM •
Lexmark...
Answered
on Nov 19, 2009
Space bar key doesn't work
If the keys do nothing at all you probably need a keyboard, if they do something but not what you want try a little WD40 on the silver shaft that guides the carrier. If it's the KB contact Geo. Beyers Co.
1-800-392-8085
8/21/2009 8:30:09 PM •
Lexmark...
Answered
on Aug 21, 2009
Improper charcters
You didn't say what kind of typewriter it is or if it only happens on the symbol keys.
9/17/2008 9:46:38 PM •
Lexmark...
Answered
on Sep 17, 2008
Carriage return not working
Turn off T/W and see if the carrier will move back and forth freely, if so try removing the batteries and unplugging the machine this will reset to defalt settings. CAUTION THIS WILL ALSO CLEAR YOUR MEMORY!! If the carrier is hard to move a little light oil on the shaft it slides on may cure the problem.
DickyO
3/25/2008 7:53:13 PM •
Lexmark...
Answered
on Mar 25, 2008
