20 Most Recent
Lexmark Wheelwriter 1500 Typewriter Questions & Answers
Hammer not working
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
2/23/2015 2:30:01 PM •
Lexmark...
Answered
on Feb 23, 2015
Print wheel hammer
Your problem is probably the print solenoid either not firing or the cap that is on the end of it has broken off. Usually the cap is broken and a new one can be installed in its place.
1/7/2015 1:57:53 AM •
Lexmark...
Answered
on Jan 07, 2015
Ww 1000
You probably need a new power supply.
1/7/2015 1:47:58 AM •
Lexmark...
Answered
on Jan 07, 2015
Wheelwriter keeps beeping
If it beeps on every key stroke try code "S" if it beeps after a word try code "1" if it just beeps and nothing else you need a tech.
DickyO
9/30/2014 7:03:12 PM •
Lexmark...
Answered
on Sep 30, 2014
How to turn on auto return?
Should be a Switch to do so, if you didn't find it, please refer to user manual or contact your Dealer or Manufacturer's Helpline.
4/26/2014 1:01:59 PM •
Lexmark...
Answered
on Apr 26, 2014
Letters to close
The pitch (spacing) is set by the print wheel. 10. 12, 15 or PS.
the only way to change thr spacing is to change the print wheel.
DickyO
2/13/2014 12:51:28 AM •
Lexmark...
Answered
on Feb 13, 2014
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
6/17/2013 3:58:58 AM •
Lexmark...
Answered
on Jun 17, 2013
My Carriage moves all the way left, hits the stop, then errors out.
wo things first spray a little WD40 on the silver shaft that the carrier slides on, if that dosen't work you have to get some lube on nthe carrier motor bearings located on the loweright rear under the case.The front one can be accessed from inside the T/W the rear you have to fish the straw thrfu the case.DickyO
10/5/2012 3:05:50 PM •
Lexmark...
Answered
on Oct 05, 2012
