20 Most Recent Kyocera KM-1510 Copier Questions & Answers
enter the service mode by pressing 10871087 .there will be U000 then press 163 through keypad then press START button 4 times machine will restart .wola. check ur input voltage it is fluctuating
Kyocera KM-1510... | Answered on Oct 17, 2019
Try this:
Press and hold stop, start, and left exposure key in that order.
Release and press stop again. Use zoom keys to enter 163, press start.
Exit the mode by entering 001 and start, or power off/on.
Kyocera KM-1510... | Answered on Mar 29, 2019
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Kyocera KM-1510... | Answered on Feb 04, 2019
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
Kyocera KM-1510... | Answered on Jul 10, 2018
press 1087 1087 than insert 163 than press start 4 time
Kyocera KM-1510... | Answered on Aug 31, 2016
This is a jam error code check the exit sensor replace if faulty
Kyocera KM-1510... | Answered on Jan 22, 2016
my dear chek LD UNIT
Kyocera KM-1510... | Answered on Jul 08, 2015
clean mirror and ccd camera
side door open here fusing unit
c4000
The Problem:
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the LSU.
3-Defective engine PCB
Replace the engine PCB and check for correct operation.
This wat the service manual say about this error code but as Tech i recommand for you to do this steps before changing any part and this 60% could fix your problem.
First of all open the back of your machine and make sure there is no cable connector is lose, specially those cables that connected to motors, unplug those cables and plug them again, also make sure that the paper fader cable is connected well. after this put the machine on and off and do this steps:
In the operation panel hit 1087 twice, and this will take you to maintenance mode , then select 906 and hit start, look for the words in the screen, hightlight it and hit start again, the machine may be will tell you put the main power off and on, do this and you will be ok.
hope it helps
Kyocera KM-1510... | Answered on Aug 06, 2014
You need to have the developer changed.
Kyocera KM-1510... | Answered on Jun 25, 2014
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Kyocera KM-1510... | Answered on Mar 04, 2014
Kyocera KM-1510 Copier Logo
122 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
kyocera mita km km 1635 displays error
  • Office Equipment & Supplies
