20 Most Recent
Bose Acoustimass 15 System Questions & Answers
Replace fuse bass module
If there are no obvious screws holding the back in place, then the only way to have access is to remove the grill, remove the speaker and go in from that end to perform the needed repair of the connector. You can remove the wires from the speaker so it does not get in the way as you use the speaker opening for access. good luck.
Location of serial number on Bose L1 s1
The serial numbers for the L1® 1S Cylindrical Radiator®s are on the back. The serial number for the Power Stand is on the bottom of one of the legs.
Sorry, I can't help with the Acoustimass system.
