20 Most Recent InFocus LP70+ Multimedia Projector Questions & Answers
7answers
Projector powers on but no picture.
depends on how many times the orange light blinks also when you replaced the lamp did you do a timer reset? you can find alot of information on how to trouble shoot this www.infocus.com/support
12/24/2021 7:29:48 PM • InFocus LP70+... • Answered on Dec 24, 2021
7answers
Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
3/13/2019 4:27:22 PM • InFocus LP70+... • Answered on Mar 13, 2019
5answers
Lp70 projector Error message about Fans
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
4/10/2018 5:55:53 PM • InFocus LP70+... • Answered on Apr 10, 2018
0answers
2answers
Vvme-htpcd-v01 projector has black spot on screen
I have the same issue. Anyone find a solution?
3/18/2015 1:40:23 AM • InFocus LP70+... • Answered on Mar 18, 2015
How can I get firmware, if it was already deleted from the manufacturer website?
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
1/31/2015 9:17:02 AM • InFocus LP70+... • Answered on Jan 31, 2015
My LP70 has a shaded area on one side of the
it is the integrator rod (light tunnel) that is collapsing. you can replace it, but it's quite involved. you can get the part (and installation help) from av solutions in ny. they're an infocus service center. or if you want to send it in for repair, they do that too. www.avsolutionsny.com
1/28/2015 3:23:52 PM • InFocus LP70+... • Answered on Jan 28, 2015
0answers
0answers
Jammed projector lens infocus lp770
get a wide bladed flathead and find the widest part of the **** between the focus ring and zoom. work the blade like you are trying to widen the the slot, do this all the way around till it pops back into place.
11/3/2013 12:04:07 PM • InFocus LP70+... • Answered on Nov 03, 2013
2answers
is it an optoma or an infocus? if it is the infocus, it needs to be replaced. however, to replace it, you need to remove the entire optical engine. now off of that, remove the clorwheel and clip, the main board, and the tunnel (on this model it is called an integrator rod) assembly. to get that out, remove the 3 tap screws and the large screw. once you can slide it out, remove the foil from the front, slide out the inside tunnel assembly, remove the clip, then the tunnel. because the clip is an exact fit, you cannot have anything on the tunnel that increases the size. reverse the instructions to reassemble (but you will need to replace the foil with a new one). warning: you now need to realign the tunnel using 2 of the tap screws. if you have not done this before, it is very difficult and dangerous, as you need to have the projector powered on and the screws are way inside next to the power supply. there is a risk of electrocution and damage to the projector. best bet- send it in to an authorized infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
9/19/2013 9:11:46 PM • InFocus LP70+... • Answered on Sep 19, 2013
InFocus LP70+ Multimedia Projector Logo
245 questions posted
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • InFocus Office Equipment & Supplies
Most Popular Question
when power
  • Office Equipment & Supplies
