20 Most Recent Sansui RZ-3200AV Questions & Answers
May I know the model no. of your TV, what are you using for the connections (RCA cord or HDMI)?
Let me know to assist you further.
Jdvillanueva
Sansui RZ-3200AV | Answered on Mar 27, 2011
The set has bad capacitors and an ic that needs to be replaced in order to rectify the problem, and there is a chance that bad solder joints will need to be addressed with a soldering iron.
Sansui RZ-3200AV | Answered on Feb 16, 2011
Unfortunately a manual is not available for it. Try unplugging it from the mains and then remove the back up battery if it has one. Leave it out for 15 minutes and replace it. The clock and alarm should now be reset. You just have to set the time which is usually easy.
https://www.google.com/search?q=sansui+4513+clock+radio+manual
Sansui Audio... | Answered on Aug 15, 2019
Hello David, I sent you the link where you can download the Sansui 220 circuit
Greetings Franco Dosil
Hola David, te envio el link donde puedes descargar el circuito del Sansui 220
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/sansui/220.shtml https://www.radiomuseum.org/r/sansui_220.html https://audiokarma.org/forums/index.php?threads/sansui-220.521305
Sansui Audio... | Answered on Jul 22, 2019
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Audio Players &... | Answered on Jul 21, 2019
Hello Marc, for what you comment, you can have several possibilities of failure, first you should see the belts of the mechanics, that are not stretched or cut, on the other hand, when you press the play key, the engine should work, otherwise it does , you could have the wrong engine or the key that sends current
I sent you the link to download the service manual
I hope you can solve it and enjoy your Sansui
Hola Marc, por lo que comentas, puedes tener varias posibilidades de falla, primero deberias ver las correas de la mecanica, que no se encuentren estiradas o cortadas, por otro lado, cuando presionas la tecla play, el motor deberia funcionar, sino lo hace, podrias tener mal el motor o la llave que le envia corriente
Te envio el link para que descargues el manual de servicio
Espero puedas resolverlo y disfrutar de tu Sansui
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Sansui-SC-2000-Service-Manual.pdf
Elektrotanya for electronics experts
https://www.hifiengine.com/manual_library/sansui/sc-2000.shtml
Sansui Audio... | Answered on Jun 20, 2019
Hello Chris, try to clean the volume controls, balance, tone and switching keys, with some clean contact spray, be very careful in the amount you apply, always try applying a drop of the cleaner and watch if the noise level goes down If you do not achieve results, you should replace the controls that generate the noise
Look for a good specialized technical service
Hola Chris, prueba limpiar los controles de volumen, balance, tono y las llaves de conmutacion, con algun aerosol limpia contactos, se muy cuidadoso en la cantidad que le apliques, prueba siempre aplicando una gota del limpidor y fijate si baja el nivel de ruido, si no logras resultados, deberias reemplazar los controles que te generan el ruido
Busca un buen servicio tecnico especializado
Sansui Audio... | Answered on Jun 13, 2019
Sad to say it's likely to be 1 or more transistors in the power amp circuit, although there are other possible causes.
Luckily the repair manual is available (hifiengine.com) and the power amp is built with discrete components, so it should be easily repaired
Most common causes would be an output transistor or dry solder joint(s) due to transistors / resistors getting hot and cooking a solder joint or 2.
Inspect all solder joints carefully with a magnifier, looking for signs of localised heating/burning and/or crysalisation of the solder.
It's normal to replace output transistors as a matched pair even when only one has failed, to minimise distortion. Replacement transistors should of course be as close to the original specs as possible (or better) if genuine parts are not available. The bias will need to be adjusted as per manual (1.5mV emitter to emitter of output transistors).
Good luck.
Sansui Audio... | Answered on May 14, 2019
Hello, from what you describe there may be several reasons for this to happen
First, lower the volume to the position between No. 4 and No. 5 of the adjustment range, then select an input that you have a CD or DVD player OR simply put the radio and tune to a station, after having something that give you sound, verify that Tape / DAT and VCR1 controls are not enabled, since they cancel the listening directly, if you can not solve it, verify that the jumpers on the rear panel correspond to the input and Processor output
I sent you a photo that tells you what I describe
If you have technical knowledge I send you the link to download the service manual
If with all this checked, you do not have positive results, go to a specialized technical service
I hope I can hear your Sansui soon
Hola, por lo que describes puede haber varios motivos para que esto ocurra
Primero, baja el volumen a la posici?n entre el N°4 y el N°5 del rango de ajuste, luego selecciona una entrada que tengas un reproductor de CD o DVD O simplemente pon la radio y sintoniza una estaci?n, luego de tener algo que te entregue sonido, verifica que no est?n habilitados los controles de Tape/DAT ni los de VCR1, ya que estos anulan la escucha directamente, si as? no logras resolver, verifica que se encuentren los puentes en el panel trasero que corresponden a la entrada y salida del Procesador
Te envi? una foto que te indica lo que te describo
Si tienes conocimientos t?cnicos te env?o el link para que descargues el manual de servicio
Si con todo esto comprobado, no tienes resultados positivos concurre a un servicio t?cnico especializado
Espero que pueda escuchar pronto tu Sansui
https://www.hifiengine.com/manual_library/sansui/rz-5000.shtml
Sansui Audio... | Answered on May 01, 2019
Hello Tracie, the PT260A team, does not have connections for the equalizer, what you can do is connect your audio source to the equalizer input and output it to an amplifier input
If you have more than one input that you want to equalize, then you should have a small sound mixer, connecting to this the different sources to play and the output of the console to the input of the equalizer and the output of this to the amplifier
Hola Tracie, el equipo PT260A, no cuenta con conexiones para el ecualizador, lo que puedes hacer es, conectar tu fuente de audio a la entrada del ecualizador y la salida del mismo a una entrada del amplificador
si tienes mas de una entrada que quieras ecualizar, entonces deberias contar con un mezclador de sonido chico, conectando a este las distintas fuentes a reproducir y la salida de la consola a la entrada del ecualizador y la salida de este al amplificador
Sansui Audio... | Answered on Apr 15, 2019
Hello Nick, the Bias control, is used to optimize the polarization of the recording-playback head, at the time of recording, depending on the type of tape you use, you have to try
A lot of Bias level, it can give you good bass recording, but the highs can be missing, you have to go regulating, starting from the central position and turning to + or to - and find the sound you like in the recording
Hola Nick, el control de Bias, se utiliza para obtimizar la polarizacion del cabezal de grabacion-reproduccion, en el momento de grabacion, dependiendo del tipo de cinta que utilices, tentras que ir probando
mucho nivel de Bias, puede darte buena grabacion de graves, pero los agudos pueden faltar, tienes que ir regulando, partiendo desde la posicion central y girando para + o para -- y encontrar elo sonido que te agrade en la grabacion
Hi, I do not think replacing fuses, you get the Sansui team to respond, I think you have a problem with the speaker output, that's why the fuses are burned
Hola, no creo que reemplazando fusibles, logres que el equipo Sansui responda, yo creo que tienes un problema en la salida de parlantes, por eso se queman los fusibles
Hello Bernard, for your description of the fault, the Sansui AU-33 team, has problems in the output stage of speakers or in the power supply stage, you should go to a specialized technical service
Hola Bernard, por tu descripcion de la falla, el equipo Sansui AU-33, tiene problemas en la etapa de salida de parlantes o en la etapa de fuente de alimentacion, deberias concurrir a un servicio tecnico especializado
Popular Tags
8 questions posted
Top Sansui Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Chris
Andrew Taylor
Andrew Taylor
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Audio Players & Recorders
Most Popular Question
please let me know
  • Audio Players & Recorders
