20 Most Recent
Samsung GTB3310 Cell Phone Questions & Answers
Network sim unlock
To unlock your Samsung B3310 phone from network lock,use unlock code.Specify the current network and country it is locked now.Get the unlock code from
Mobile-unlocker.com and unlock it easily.You can unlock from only GSM network.You cannot unlock CDMA network.To get you also need to specify current network,country it is locked now and IMEI number.
Samsung b3313 not charging
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
