20 Most Recent Sansui COM311AD 13 in. Combo Questions & Answers
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
Sansui COM311AD... | Answered on Feb 18, 2013
see previous answer I made to nearly identical question you posted.
Sansui COM311AD... | Answered on Mar 14, 2012
several types of connections possible:
A unit with yellow, red and white is yellow is video, red and white are left and right audio.
This is called COMPOSITE as all video/color are on yellow and red and white only for sound or audio.
If the DVD has RED,GREEN, and BLUE the hookup must be to similar connections on the set---this is called COMPONENT and green carries the video and red and blue the information for those colors.
Let me know if issues or questions as I am here to help you
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Sansui COM311AD... | Answered on Jan 28, 2012
No,the tv was previous in the Hotels or hospitals.This type of tv is special designs for Hospitals and Hotels.
Sansui COM311AD... | Answered on Feb 26, 2010
i have sansui sv-2102.now i change ic tea5101a and i put tea5101b.now i have probelem with green picture. tea5101a not avilable.now what can i do ?
Sansui COM311AD... | Answered on Aug 31, 2008
on some tv's the menu can be accessed by pushing both channel up and down buttons at the same time. otherwise you may just have to get an all in one programmable remote control.
Sansui COM311AD... | Answered on Aug 26, 2008
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
Sansui COM311AD... | Answered on May 13, 2008
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Sansui COM311AD... | Answered on May 05, 2008
either use an old vcr to act as a signal converter or go buy an "rf converter" from an electronics store to change composite audio/video signal to channels 3 or 4 and that should do the trick.
if your tv has a headphone jack and your truck has a cassette player, they make an adapter in the shape of a cassette with a wire running out of it and a small jack that will hook into the tv and you should get sound out of your truck stereo. if no cassette player, then they also make an fm transmitter that will hook into the tv and then you tune your fm radio to the frequncy required. radio shack or some place like it usually carries things like this.
It should show it on the old cord, or on the DC jack on the TV set. A little diagram should be right by it.
Sansui COM311AD... | Answered on Apr 05, 2008
Pour some rubbing alcohol into playr or on buttons..it breaks them back to life from the corrosion..use only 70% or more
Sansui Televison... | Answered on Jan 07, 2020
try a head cleaner or a cutip with alcohol open door and turn heads by hand and clean with unit unplugged
Sansui Televison... | Answered on Jan 04, 2020
Already answered on your earlier post/
Short answer, analog probably not possible.
Maybe if you get a digital antenna and you have stations in your area.
i think sanui sv-pd42t havea USB port.But I am view on his black side
Sansui Televison... | Answered on Dec 25, 2019
Use code search on the remote control to find something that works. If a search through all codes stored in the remote control fails, try a different one.
Sansui Televison... | Answered on Dec 16, 2019
Televison & Video Logo
22 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
given sansui com311ad tv in
  • Televison & Video
