? 0:59https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
? 7:13https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
? 4:10https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
The old yellow, red, white RCA cables are analogue signals, while HDMI cables only carry data. They are in no way compatible. You can buy active conversion boxes that will convert analog to digital, but simple cables cannot work
It can't be done. The Samsung remote will be single frequency for that Samsung device only and the LG remote for that television (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television.
If you have lost a remote or it doesn't work, this is the answer
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
I think you need to check the color settings on your new LG TV and ensure all cables are securely connected. If the issue persists, you don't have further options except to contact LG support for assistance.
I suggest an authorised Samsung repair agent, (a list can be found on the Samsung web site), otherwise you will get panel changers and not engineers that repair to component level.
One common culprit of this issue power supply issue, caused by a faulty power supply unit or the TV not receiving enough power, caused by faulty electrolytic capacitors on the Power Supply board.
See troubleshooting section of this manual. It will help.
[ENG_US]GPATSCA-1025.pdf (samsung.com)
For further help you can use following link
PN59D8000FF ' Samsung Support CA
