20 Most Recent
Zenith SY1931SG TV Questions & Answers
I am a former employee,where do i find my W2 form on line?
Your former employer should automatically send you a W2 for 2013, if you received any wages and had any withholdings during 2013. If necessary, contact the former employer, their Human Resources Dept. and ask they mail you a W2, or ask them how you can access and print out your W2 from their website.
The remote control for Zenith
You can get an adequate Universal remote at a dollar store, or a general dollar,
or a dollar general, or an ollies, or a big lots, real cheap.
And you might be able to use it for everything in the house!!!!!
Please COME BACK AND RATE!!!
The volume won't stay up.
your TVs front panel control swwiches are in trouble. Replace all of the at the same time will resolve the problem.
Can't get my zenith TV off Video mode
not sure what year this tv is, but I had some where the tuner was bad and would be stuck on video. The only way is replacing the tuner. Or you may want to try hooking up a vcr into the video audio jacks and run the channels from the vcr it may work yet.
Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
