20 Most Recent
Brother HL 2700CN Laser Printer Questions & Answers
Error el1 after i've cleaned the printer with with
You will probably find there is some toner on the left hand edge of the OPC belt that interferes with the optical sensor reading the page rotation mark on the edge of the OPC. It may also have coated the optical sensor that is in front of the left hand edge of the OPC belt
Unload output tray
The Tray Full indicator lights on the appropriate stacker tray
(applies to dual stacker only).
A message displays on the printer control console that
indicates which output tray is full.
In automatic switching mode, the system automatically
switches over to the second tray (if it is empty) when one
tray is full (applies to the dual stacker only).
If only one tray was selected or if both output trays are full,
the printer stops.
The picture on the graphic display shows the location of the
full tray.
Still having Problem Then follow Us For
Brother Printer Support
Error EE9 on Brother HL-2700CN
This is a sensor error (belt marker).
Could be a piece of paper or such stuck in there from a previous jam futzing up the sensor.
Are you comfortable poking around inside your printer?
HL 2700cn red and green
I have similar symptoms with my HL 2700CN. However, web interface to printer shows device status and reports "Missing Tray 1" error. (Tray 1 is present). Printer Firmware version number is reporting junk number, implies possible firmware corruption. I'm still investigating.
Error ee9
ERROR EE9 WARNING
Belt marker sensor error Turn off the printer. Wait a few seconds, and then turn it on again.
Error message: replace opc belt
You will not like this but the OPC Belt (Organic Photo Conductor) needs to be replaced
They are not cheap.
to order this part call:
Southeast Digital Networks, Inc.
850-681-9528
Authorized Brother Elite Service Center.
Parts Center.
Jamming and now EF5 Warning
1. ejected the opc belt (there's a hatch on the top)
2. turned the mechanic wheels forward and back
3. inserted opc belt
4. turned on/off
5. printed a test page
Paper will not feed from
if you have been printing a lot, the feed roller could be dirty or just plain old and hard. cleaning with alcohal could do it if it's dirty, if hard, it needs to be changed.
HL2700 Error EF5
Seems that you can't fix the problem, 'BROTHER' should recall all of these and give us new printers. Big dollars have been spent on the printer, the only solution is, that you are told to switch off the printer and on again and see what happens.
This unit is heavy and it costs big dollars to get someone out to have a look at it.
BROTHER promises big but delivers small in this case.
