20 Most Recent Zenith SY2765S TV Questions & Answers
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
4/23/2016 10:33:35 AM • Zenith SY2765S... • Answered on Apr 23, 2016
Flyback transformer number please
i dont know the number
10/19/2013 5:32:33 AM • Zenith SY2765S... • Answered on Oct 19, 2013
My 1996 Zenith TV sy2765s
HelloCheck it LOT {Line Output Transformer] and line output transistor.
3/4/2012 8:14:52 AM • Zenith SY2765S... • Answered on Mar 04, 2012
Where do i find INPUT SELECTon zenith tv
Most tv's have a physical button on the front and it will either be labeled input or source-source select. If thats not the case on your tv, look for a menu button and try to navigate through the tv menus until you find tv input or source select. If that still does not work, you can use your dish 500 remote and if you already use that to turn the tv on and adjust volume, you can probably use it to change the input. To do this, select the tv mode on your dish 500 remote, and then press the source or input button until you get to where you need to be. Once thats done, make sure you return your remote to sat mode or you will not be able to control the dish reciever. Hope this was helpfull to you.
Thanks
1/3/2011 2:41:41 AM • Zenith SY2765S... • Answered on Jan 03, 2011
Tv is dark
looking on the back of ur tv near the cable input jack there might be an area where u can adjust the brightness on the flyback transformer. if there isn't you will have to remove the back of the tv and adjust it this way. PLEASE DO NOT TOUCH ANYTHING OTHER THAN THE BRIGHTNESS KNOB ON THE FLYBACK, CAUSE YOU MAY BE SHOCKED. so please be careful.
8/4/2010 6:10:08 PM • Zenith SY2765S... • Answered on Aug 04, 2010
Remote problem
seems that the on/off button on the remote may be bad. when pressing this button look and see if the remote is lighten up indicating its working. if this button does not light up, but when changing the channel or volume it does, then the on/off button is bad.
8/4/2010 6:05:44 PM • Zenith SY2765S... • Answered on Aug 04, 2010
I need to program without a remote. I have cable,
if the tv does not have a menu function on the front of it then it is impossible. you will have to buy the original remote offline somewhere. you may try an universal remote, but can't guarantee this will work.
8/4/2010 5:58:17 PM • Zenith SY2765S... • Answered on Aug 04, 2010
How do you get it to dvd mode
depending on how old the tv is and if it has av jacks. try using channel 2 or 3.
8/4/2010 5:51:40 PM • Zenith SY2765S... • Answered on Aug 04, 2010
2answers
Rainbow screen, no color, tv fell over
ur tv needs to be degaused using a degausing wand or ring. mos def needs to be taken to a professional to be done.
8/4/2010 5:49:24 PM • Zenith SY2765S... • Answered on Aug 04, 2010
I can't seem to change the channel from Channel 2
I have a Sony 27" TV. I tried the same thing on mine. I couldn't change the channel either. You will have to buy a cheap universal remote that will have a code on it for your TV.
7/23/2010 1:47:43 AM • Zenith SY2765S... • Answered on Jul 23, 2010
Picture out of focus
a part clled picture tube base is gone i think!
1/17/2010 1:44:57 PM • Zenith SY2765S... • Answered on Jan 17, 2010
White Lines and Bright Screen
I believe you have a shorted transistor on the crt board on the back of the picture tube which should be Q5104. Let me tell you my experience with these Zenith's The original problem is the picture tube shorting out and caused this problem. If you replace the transistor the same problem could arise again because of the tube and it could even knock out the main board power supply. I have seen this happen. And I have put in the transistor and no problem. You can get one at the Radio Shack by taking the bad one out and get them to cross reference it for you. All Zenith transistors have a prefix number (not on the transistor) which is 121- (with the dash!) and the number on the transistor The new one must go back in the way it came out! I recommend someone with electronic soldering and desoldering experience. Hope this helps
12/30/2007 2:01:41 AM • Zenith SY2765S... • Answered on Dec 30, 2007
Blue Box in the Corner won't turn off!
That problem might be on the remote of display settings on video display. There is one button that will turn that off. Try Display Settings
11/14/2006 4:59:26 AM • Zenith SY2765S... • Answered on Nov 14, 2006
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Where can I find a manual for my Zenith ZG120M alarm clock
Not available online, but there is a video. https://www.google.com/search?q=Zenith+ZG120M+manual ..
7/22/2022 3:24:38 AM • Zenith Televison... • Answered on Jul 22, 2022
Televison & Video Logo
14 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
rainbow screen no color tv fell over
  • Televison & Video
