20 Most Recent
Zenith SY2768S TV Questions & Answers
FixYa: Thank you for choosing to chat with an
You will not find any channels with this old TV. All channels in the USA switched to digital 1 1/2 years ago. You will need to connect a digital converter box to get any channels.
My zenith sy2768s has a
It is CRT tv and an old model. It seems CRT (picture tube) got either magnetic affect or internal grille misaligned and causing rainbow screen affect.
Demagnetize/ degaussing will cure any magnetic affects in picture tube, unplug tv from wall socket for 1 hour, replug back in and turn tv On to activate inbuilt degaussing system to remove any magnetic affects, if this does not solve picture problem then it is picture internal problem and picture tube will be replaced that would cost you more then tv worth so I would recommend to buy new tv instead of picture tube replacement.
Hope these info will help you.
Thanks.
Zenith rear projection TV
it's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Tv picture
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
A problem with the television
Just guessing but the menu button the remote may be sticking Try turning the remote away from the TV. Also the menu tact switch inside the set may be defective
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
