20 Most Recent
Brother HL 1850 Laser Printer Questions & Answers
Paper Jam in MP Tray under the Roller
Push a thick manilla envelope through the area with the machine open to try and get the pieces out. Be careful not to damage the drum unit with rings on your fingers.
PAPER JAMB - CANNOT GET TO IT
Remove the lower paper tray and turn the printer upside down there is a metal or plastic plate usually the jammed paper is underneath this look carefully there is a release mechanism that will allow access to the paper under the plate
Gray streaks on paper
Hello
Well, i would rather go with the printer itself, have you tried upgrading the firmware of the printer using the correct procedure?
If you have replaced the drum and the cartridge, and the problem have only occurred in the past couple of days, it might be the printhead as well, but, it is always best to keep the printer firmware up to date.
It sometimes happens that if the drum and cartridge is replaced that the resetting of the counters may cause firmware malfunctions.
So, have a look at the firmware, also, please do not hesitate to let me know if i can assist you in any way.
Kind regards
Andrea
Where is tray one?
I reported the same problem and decided to check one last time before I scrapped the printer. I pulled out Tray 1 (the bottom (large capacity tray) to really check closely. I discovered that there seemed to be a space between the end of the paper and the printer tray. I simply squeezed the space closed and NOW IT WORKS! I keep kicking myself for being dumb.
How do you clean the drum?
Brother had me take a tissue and wipe the drum. You can spin it with the gear on the left had side of the drum. Then they had me slide the blue tab 30 times back and forth.
Also take a soft cloth and clean the lens on the inside of the printer. First take out the drum unit. The lens in toward the back.
E50 error
E50 is fuser code, it has blown the heat lamp or thermal fuse. the best solution is to replace the fusing unit. let me know if this helps
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Things To Do When Brother Printer Shows Offline Errors
Troubled with issues via brother printer goes offline frequently? Here are few things to do when fixed.
- Begin with checking whether the machine is turned on or not
- Sometimes when you find your brother printers screen is all blank the indications could be that the machine is turned off
- Check the device properly and make sure that it wakes up from its sleep mode.
- Note that in case you cannot turn on the machine it indicates some hardware problem and does none of the below mentioned troubleshooting steps will work.
- In case there are any other kind of error messages read on the LCD screen please follow the mentioned on screen instructions to troubleshoot it
- Another trivial brother printer offline issue occurs because of paper jam
- To fix a paper jam first check on the input and output paper trays check the add cover
- Is the paper jam still exist unplug the printer and check inside the printers to remove any torn piece of paper carefully
- Printer is properly connected
Sometimes your brother printer not printing issue is contributed when the printer is not properly connected to the network or computers. To check
- If you are using any USB cable make sure the cable is connected to both the ends on printer and computer
- If using Ethernet cable make sure the cable is properly connected to the router and computer and you have a working internet connection
- The wireless connection users also should check their network connectivity
- Make sure that both your computer and your printer is connected to the same network
- Set your printer as default
To set your brother all in one printer as default follow the steps
- Go to control panel and from there go to devices and printers
- Click on the icon of your printer
- From the sub menu choose option set as default
- Deleting all pending print jobs
- To delete all pending print jobs from brother inkjet printer, go to control panel and from their go to devices and printers
- Right click on the brother printer icon and choose the option see what's printing
- Select option printer and finally choose cancel all print documents.
- Is the cancelling option is grayed out then click on option use as administrator
- Enter your option use as administrator and click on yes.
- To fix printer offline errors on Mac
- To fix brother printer offline mac error go to system preferences from Apple menu and on their go to option printers and scanners
- Select the brother printer machine from the list of drivers
- Make sure that the correct driver is selected to be used.
- At the top of the dialogue box name of the default printer icon is given
- Make sure name is printer name + CUPS
- Click to add printer and then quit system preferences
In case of unresolved issues call experts for further guidance
https://printeroffline.support/brother-printer
Lampu indikator toner menyala
gan mohon bantuan pencerahannya, di kantor saya memiliki printer LQ 2190 saat ini memiliki kendala lampu indikator merah nyala semua dan printer tidak bisa nge print, itu di sebabkan kenapa ya gan, dan bagaimana cara memperbaikinyamohon bantuan pencerahannya ya gan
