20 Most Recent Zenith C27A24T 27" TV Questions & Answers
3answers
Broken RF Connector
Its fixable. the question is how much of the inside broke with it. cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job Good luck
12/19/2020 6:28:59 AM • Zenith C27A24T... • Answered on Dec 19, 2020
0answers
Old zenith TV shuts off model c27a24t
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
9/15/2015 8:28:28 AM • Zenith C27A24T... • Answered on Sep 15, 2015
Code for Zenith tv
0281,0288. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
1/21/2015 6:41:45 AM • Zenith C27A24T... • Answered on Jan 21, 2015
How do I fix a broad wide strip on the left side of screen
Contact any service technician. Gopakumar Gopalan Google
1/11/2015 4:37:30 AM • Zenith C27A24T... • Answered on Jan 11, 2015
2answers
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
1/5/2015 12:04:44 AM • Zenith C27A24T... • Answered on Jan 05, 2015
Because I like this zenith 27 inch TV large black TV
im sorry I cannot deliver any thing. I was just helping fix things that was broke and saving people money because most things can be fixed at home very cheap instead of paying 300 dollars for a repair on a 2 dollar part. sorry if I could I would for sure.
10/2/2014 8:04:52 PM • Zenith C27A24T... • Answered on Oct 02, 2014
2answers
No Power to TV
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
7/31/2014 5:30:00 PM • Zenith C27A24T... • Answered on Jul 31, 2014
Thomson tv 28dg17ev no power
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/11/2014 3:39:22 AM • Zenith C27A24T... • Answered on Jun 11, 2014
2answers
Tv will not turn on
'AC Line Failed'
That was generated when you pulled the AC plug. This is telling you that some custom settings you might have made could be lost.
The clicking you hear is a relay that repeatedly connects, then disconnects the AC to prevent fire or further damage.
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
5/16/2014 7:02:00 PM • Zenith C27A24T... • Answered on May 16, 2014
How to troubleshoot the power supply of the tv when there is no power
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/21/2014 5:44:01 AM • Zenith C27A24T... • Answered on Apr 21, 2014
HOW TO CHECK THE REGULATOR IC
have to apply voltage to check, using multi meter can only check short circuit ,it's not accurate.
4/21/2014 2:19:03 AM • Zenith C27A24T... • Answered on Apr 21, 2014
Volume dont word
Please be clear with the fault you face with this TV. Gopakumar Gopalan Google
3/4/2014 3:09:39 PM • Zenith C27A24T... • Answered on Mar 04, 2014
Model #H25D34Y
It is its main board fault. In most cases, the main system control circuit should be troubleshooted. Contact any service technician. Gopakumar Gopalan Google
2/19/2014 2:43:02 PM • Zenith C27A24T... • Answered on Feb 19, 2014
Zenith C27A24T 27" TV Logo
269 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
need urc codes
  • Televison & Video
