20 Most Recent Sansui VRDVD4000 DVD Player/VCR Questions & Answers
Visit the site linked here to know more about set-up procedure.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
Sansui VRDVD4000... | Answered on Jan 06, 2017
If you wish to buy it's original remote control, contact the authorized service centre. To buy a universal remote control, visit the site linked below, and make sure about, which brand remote control have set up codes to your device brand, and buy that one according to availability.
its probably a chewed cord if the room its in is messy or somthing might have been spilled on it or it might be all the dust thats in it because my xbox 360 did the same thing because of the dust
Sansui VRDVD4000... | Answered on Mar 05, 2013
From the description you have provided, the microprocessor controller ic is failing which is the brains for the whole system. I suggest repacing the complete unit rather than have it repaired because it would not be cost effective.
Sansui VRDVD4000... | Answered on Mar 04, 2012
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Sansui VRDVD4000... | Answered on Nov 04, 2011
Google the make and model of your remote and add codes to the end.
Sansui VRDVD4000... | Answered on Sep 04, 2011
This canbe due to many faults and need a full check up but I can fill up with few tips.
1. if the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE swittch point or failure of mode can make the loading to trip back to rest.
Hope you are able to check these tips.
Sansui VRDVD4000... | Answered on Jul 20, 2011
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Sansui VRDVD4000... | Answered on Mar 08, 2011
Sansui models like yours usually have a free customer service phone number on the back of the unit. Call them and ask about a manual and the original remote. What have you got to lose?
May this be helpful to you. Bobya.
Sansui VRDVD4000... | Answered on Sep 24, 2010
Hello
The user manual is available from Sansui, but they will charge you 3 dollars for it, and I can't help it.
http://www.sansuiproducts.com/accessories/j2a70101d-owner-s-manual.html
J2A70101D Owner's Manual J2A70101D Overview
This item can be used for the following products:
Category Manual Models VRDVD4000, VRDVD4000A
Sansui VRDVD4000... | Answered on Sep 21, 2010
Check all belts. clean the all moving parts
Sansui VRDVD4000... | Answered on Jul 17, 2010
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Sansui VRDVD4000... | Answered on Jul 12, 2010
Check out my tip on how to best control the internal USB hub on your PC
http://www.fixya.com/support/r3841405-sandisk_u3_launcher_wont_start_conflict
Sansui VRDVD4000... | Answered on Jun 16, 2010
few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Some DVD players simply will not read/play home made dvd's, or dvd copies.
Sansui VRDVD4000... | Answered on Apr 28, 2010
Sansui VRDVD4000 DVD Player/VCR Logo
55 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
put in dvd usually use went dvd menu
  • Televison & Video
