20 Most Recent Sansui VRDVD4001 DVD Player/VCR Questions & Answers
I'm sorry but, no you need the remote. The cheapest way to go is usually to check everyone's favorite auction site for the remote for your model number combo player. There are also some sites that specialize in "replacement remotes" but , are usually more expensive. I hope this is helpful to you. Bobya.
Sansui VRDVD4001... | Answered on May 07, 2014
Unfortunately, I think the only way to fix this is to program the player into a Universal Remote.
Sansui VRDVD4001... | Answered on May 03, 2014
the only way is to purchase a region free player directly from china or japan.
Sansui VRDVD4001... | Answered on Nov 03, 2013
You can download and print the instruction manual for Sansui VRDVD4001 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Sansui VRDVD4001... | Answered on Jul 31, 2011
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Sansui VRDVD4001... | Answered on Mar 17, 2011
Unfortunately, you need the remote control to do this. You can get a replacement remote with all of the features here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12937528570080&smodel=VRDVD4001&brand_pn=SANSUI_VRDVD4001 . There are a couple of other versions of the Sansui VRDVD4001 and their remotes are also available from remotes.com. Search on the model but not the brand name.
Even the timed recording menu which doesn't need the speed button doesn't have a button on the front panel of the unit.
I wish that I had better news.
Sansui VRDVD4001... | Answered on Dec 30, 2010
I can't get any support from sansui. I think your DVD player is trying to read the disk. It can't and its stuck in DVD mode. This is just something I would try I don't know if it will work. Unplug the power source hold down the eject button and plug it back in. The objective is to try to get it to spit that disk out before it has a chance to try to read it.I hope this helps. If it does give me a vote and I'll know it worked.
Sansui VRDVD4001... | Answered on Mar 04, 2010
Hi if your tv has rca inputs simply plug yello,red,and white rca cables into the color inputs on tv if it has a coaxle "roung with threads and a hole" simply screw the coaxle wire to this and your alset.
Sansui VRDVD4001... | Answered on Feb 01, 2010
Is the clock set?
Do you have the manual?
Have you set it in the past and have it work properly?
Unplug it for an hour and re-try.
Thanks
Sansui VRDVD4001... | Answered on Jan 11, 2010
Hi.
Unfortunately the manual for this model is not available for free download.
You can download the manual for VRDVD4001 from Orion website (Orion distributes Sansui and Durabrand), and provides customer support. The manual is available for a small fee. The cost is $2.71 only. Click on the link below to access the download page:
http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=VRDVD4001
Regards.
Sansui VRDVD4001... | Answered on Jan 09, 2010
I would not put this between the sat and tv not recommended anyhow rather use RCA plugs because of the simple fact the tuner on the VHS might be on channel 4 make sure its on 3 and the tv is on 3, see if you connect this to the sat you will experience issues
Make sure if your going to do this you take the line out from the sat that otherwise goes to the tv and put it into the line IN of the vhs then from line out to the tv, the tv on channel 3 make sure the vhs switch on the back is on 3 is it has one that is. if that does not work try to hook this up via red,wht,yellow cables se prate from co axe.
Thanks I hope this information does help please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sansui VRDVD4001... | Answered on Dec 26, 2009
http://www.usersmanualguide.com/
see if you find your manual here
Sansui VRDVD4001... | Answered on May 01, 2009
I'm sorry. The VRDVD4001 does not record on DVD.
Sansui VRDVD4001... | Answered on Apr 29, 2009
for the replacement of the gear, you can try inquiring here. Its not brand new, but I guess you can try replacement using higher models of sansui.
Sansui VRDVD4001... | Answered on Apr 27, 2009
Sansui VRDVD4001 DVD Player/VCR Logo
52 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
looking user manual
  • Televison & Video
