battery is flat and will not re-charge, pries apart headband from body, locate two tiny screws holding battery in and remove by sliding
change battery and allow to charge on base for a full 24 hours
Blow gently on both the pins that sit up from the base and the hole the pins go into, if you have a soft brush, use that gently to clean.
check the pins are not bent or broken.
