20 Most Recent
Verona 34 in. CTG536S Gas Cooktop Questions & Answers
No gas coming out from all hobs
Do you have a drop down lid over the burners, if so the mechanism may be faulty. Most of this type of design has a safety cut off when the lid is shut, and it won't allow gas to flow through to the hob, lift the lid and check behind and see if it has stuck closed.
I have a 37 year old 3+! corning range which I
This sounds like replacing (or if possible - adjusting) the thermostat will fix the problem. Fortunately, thermostat technology hasn't advanced to the microprocessor level yet, so you (or your appliance repair person) should be able to find a workable replacement - assuming it isn't a real odd-ball.Some thermostats allow for minor adjustments - but not all. Since I have no idea which oven you have - there's little more I can provide.Good luck!
We have an older corning
I use a razor blade scraper to remove the heaviest deposits and then scrub it clean with Bar Keeper Friend cleaner.
Can you use metal cookware
Yes. I use metal pots and pans on mine for years. They need a flat bottom. Heavey bottomed pans work best - Thin pans don't transmit the heat well,
My problem is similar to
I'm slightly unclear as to the exact nature of your problem as this is listed as a "Gas Cooktop" problem. You refer to elements but these are only found in electric cooktops. A gas cooktop has gas burners. You also stated that you thought the switches were fine, but then asked if you would be able to obtain replacement switches.
Please work with me a little to help you identify the cause of the fault and help you obtain any parts that you may ultimately need.
Regardless of whether the cooktop is electric or gas, you should be able to interchange the control knobs on the cooktop. These should simply pull off of the spindles.
If the knobs from the switches that currently do not engage also do not engage when put on a different spindle, then it is the control knobs that need replacing. If the knobs from the switches that currently engage, do not engage when put on the spindles that you are already having difficulty with, then it is the switches that probably need replacing.
In the case of gas cooktops, these would be control valves rather than switches as switches are electrical parts.
I hope you understand the reason for my slight confusion. Please can you let me the know the correct brand and model of your cooktop and whether it is electric or gas. Please also try the test described above with the control knobs and let me know the results.
I will then be able to assist you in determining which parts are needed (if any) and point you in the direction of a reputable supplier. It would also help if you could state your location
I await your reply.
Regards,
BElectric
Oven problems-electric plugs on oven face don't work
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I HAVE A CORNING COUNTERANGE.
YOUR ADVISE DID NOT POSE A SOLUTION TO MY PROBLEM. I THINK YOU SHOULD REFUND THE TWENTY DOLLAR FEE YOU CHARGED ME FOR LESS THAN FIVE MINUTES OF "CHAT". NEITHER OF THE WEB PAGES HAD ANY HELPFUL INFO. WHAT A RACKET YOU HAVE GOING!
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
